How Can I solder the SATA adapter on a SAMSUNG ST500LM016, HN-M500XBB
Best regards
SAMSUNG ST500LM016
Moderator: Garry_TS
Re: SAMSUNG ST500LM016
USE pcb from HN-M500MBB
Thank you for your reply AJ2008 i will try that
You have to find two differential paired PCB traces that are comming from USB bridge to main IC and unsolder 4 capacitors.
Same way like in ST2000LM005.
As alternative you can use any SATA PCB from same family with same processor.
