Hello everyone, I've got a HDD whose details are as follows,
Hitachi 2.5"
Model - HTS543225L9A300
Capacity - 250GB
Spinning normal. getting redy.
When clicked Auto Detect, shows ABR and ERR.
There are three utilities - Hitachi IBM, Hitachi IBM-ARM, Native 2.5 inch families.
Asking for COM port in 2.5 inch utility but no terminal port available in HDD.
And shows the following log when tried Custom Family in Hitachi-IBM utility -
Techno mode key......................... : Error
WARNING! SET FEATURES subcommand required to spin-up after power-up!
Loading data for correction of HDD family handling settings from section HTS5416J9
Loading data for correction of HDD family handling settings from section HTS5425K9
Selected family......................... : CUSTOM
Model by ID............................. :
Loading data for correction of HDD family handling settings from section HTS5432L9
Error : .............................................................. : Error executing loading "open" modules dir command
How to handle this HDD?
Hitachi HTS543225L9A300 not showing ID!!
Re: Hitachi HTS543225L9A300 not showing ID!!
Family autodetect does not work for Hitachi 2.5".
Select family manually from model number and check modules. There will probably be some damaged ones there.
Thanks for reply,
I manually selected family..
in IBM -> costume mode -->HTS5416J9..
Loading data for correction of HDD family handling settings from section MEM_P
It shows..
its Ready.. No Model, Serial,
Capacity 0MB
Firmware C40C
Its correct Output ? What next to do ?
Thanks for reply,
It shows..
Capacity 0MB
Firmware C40C
pcimage already explained next steps you need to take:
pcimage wrote:Select family manually from model number and check modules. There will probably be some damaged ones there.
Hello all,
Kindly find below the result of modules. What is the interpretation? And how to solve these errors in the modules?
Test : SA structure test
Module checking
Module RSVD Copy 0...................... : Ok
Module RSVD Copy 1...................... : Ok
Module RESF Copy 0...................... : Ok
Module RESF Copy 1...................... : Ok
Module RESF Copy F...................... : Ok
Module RAM0 Copy 0...................... : Ok
Module RAM0 Copy 1...................... : Ok
Module RAM0 Copy F...................... : Ok
Module OVR0 Copy 0...................... : Ok
Module OVR0 Copy 1...................... : Ok
Module OVR0 Copy F...................... : Ok
Module RESF(1) Copy 0................... : Ok
Module RESF(1) Copy 1................... : Ok
Module RESF(1) Copy F................... : Ok
Module PTCH Copy 0...................... : Ok
Module PTCH Copy 1...................... : Ok
Module PTCH Copy F...................... : Ok
Module CNS1 Copy 0...................... : Ok
Module CNS1 Copy 1...................... : Ok
Module CNS1 Copy F...................... : Ok
Module RWCN Copy 0...................... : Ok
Module RWCN Copy 1...................... : Ok
Module RWCN Copy F...................... : Ok
Module ZONE Copy 0...................... : Ok
Module ZONE Copy 1...................... : Ok
Module ZONE Copy F...................... : Ok
Module PTRT Copy 0...................... : Ok
Module PTRT Copy 1...................... : Ok
Module PTRT Copy F...................... : Ok
Module SRVP Copy 1...................... : Ok
Module SRVP Copy F...................... : Ok
Module SRVM Copy 0...................... : Ok
Module SRVM Copy 1...................... : Ok
Module SRVM Copy F...................... : Ok
Module CHNL Copy 0...................... : Ok
Module CHNL Copy 1...................... : Ok
Module CHNL Copy F...................... : Ok
Module IDNT Copy 0...................... : Ok
Module IDNT Copy 1...................... : Ok
Module IDNT Copy F...................... : Ok
Module SN00 Copy 0...................... : Ok
Module SN00 Copy 1...................... : Ok
Module SN00 Copy F...................... : Ok
Module MISC Copy 0...................... : Ok
Module MISC Copy 1...................... : Ok
Module MISC Copy F...................... : Ok
Module ICES Copy 0...................... : Ok
Module ICES Copy 1...................... : Ok
Module ICES Copy F...................... : Ok
Module MLBA Copy 0...................... : Ok
Module MLBA Copy 1...................... : Ok
Module MLBA Copy F...................... : Ok
Module QMCN Copy 0...................... : Ok
Module QMCN Copy 1...................... : Ok
Module QMCN Copy F...................... : Ok
Module SMRT Copy 1...................... : Ok
Module SMRT Copy F...................... : Ok
Module PNID Copy 0...................... : Ok
Module PNID Copy 1...................... : Ok
Module PNID Copy F...................... : Ok
Module ABLP Copy 0...................... : Ok
Module ABLP Copy 1...................... : Ok
Module ABLP Copy F...................... : Ok
Module ABLD Copy 0...................... : Ok
Module ABLD Copy 1...................... : Ok
Module ABLD Copy F...................... : Ok
Module SSTL Copy 0...................... : Ok
Module SSTL Copy 1...................... : Ok
Module SSTL Copy F...................... : Ok
Module SERL Copy 0...................... : Ok
Module SERL Copy 1...................... : Ok
Module SERL Copy F...................... : Ok
Module SSST Copy 0...................... : Ok
Module SSST Copy 1...................... : Ok
Module SSST Copy F...................... : Ok
Module SKPO Copy 0...................... : Ok
Module SKPO Copy 1...................... : Ok
Module SKPO Copy F...................... : Ok
Module DCOT Copy 0...................... : Ok
Module DCOT Copy 1...................... : Ok
Module DCOT Copy F...................... : Ok
Module SRIF Copy 0...................... : Ok
Module SRIF Copy 1...................... : Ok
Module SRIF Copy F...................... : Ok
Module BULK Copy 0...................... : Ok
Module BULK Copy 1...................... : Ok
Module BULK Copy F...................... : Ok
Module ALTT Copy 0...................... : Ok
Module ALTT Copy 1...................... : Ok
Module ALTT Copy F...................... : Ok
Module DBGC Copy 0...................... : Error
Module DBGC Copy 1...................... : Error
Module DBGC Copy F...................... : Ok
Module OFDT Copy 0...................... : Ok
Module OFDT Copy 1...................... : Ok
Module OFDT Copy F...................... : Ok
Module SMRA Copy 0...................... : Ok
Module SMRA Copy 1...................... : Ok
Module SMRA Copy F...................... : Ok
Module RDMT Copy 0...................... : Ok
Module RDMT Copy 1...................... : Ok
Module RDMT Copy F...................... : Ok
Module RELI Copy 0...................... : Ok
Module RELI Copy 1...................... : Ok
Module RELI Copy F...................... : Ok
Module PSHT Copy 0...................... : Ok
Module PSHT Copy 1...................... : Error
Module PSHT Copy F...................... : Ok
Module OVR1 Copy 0...................... : Ok
Module OVR1 Copy 1...................... : Ok
Module SPRE Copy 0...................... : Ok
Module SPRE Copy 1...................... : Ok
Module PESD............................. : Ok
Module MFGP............................. : Ok
Module SRST............................. : Ok
Module FLOG............................. : Ok
Module DUMP............................. : Error
Module ##01 Copy 0...................... : Ok
Module ##01 Copy 1...................... : Ok
Module ##01 Copy F...................... : Ok
Module PIDM is not found!
Module not created! PIDM
Test : Reading modules
Reading modules to profile folder (composite)
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\HITACHI-IBM\CUSTOM\-UnknownHDD\Data\Modules
Module RSVD............................. : Ok
Module RESF............................. : Ok
Module RAM0............................. : Ok
Module OVR0............................. : Ok
Module RESF(1).......................... : Ok
Module PTCH............................. : Ok
Module CNS1............................. : Ok
Module RWCN............................. : Ok
Module ZONE............................. : Ok
Module PTRT............................. : Ok
Module SRVP............................. : Ok
Module SRVM............................. : Ok
Module CHNL............................. : Ok
Module IDNT............................. : Ok
Module SN00............................. : Ok
Module MISC............................. : Ok
Module ICES............................. : Ok
Module MLBA............................. : Ok
Module QMCN............................. : Ok
Module SMRT............................. : Ok
Module PNID............................. : Ok
Module ABLP............................. : Ok
Module ABLD............................. : Ok
Module SSTL............................. : Ok
Module SERL............................. : Ok
Module SSST............................. : Ok
Module SKPO............................. : Ok
Module DCOT............................. : Ok
Module SRIF............................. : Ok
Module BULK............................. : Ok
Module ALTT............................. : Ok
Module not read (DBGC)
Error : Device error detected (UNC)
Module DBGC............................. : Error
Error : ModStg: composite reading impossible - reading error!
Module OFDT............................. : Ok
Module SMRA............................. : Ok
Module RDMT............................. : Ok
Module RELI............................. : Ok
Module PSHT............................. : Ok
Module OVR1............................. : Ok
Module SPRE............................. : Ok
Error : Module not read (DUMP)
Module ##01............................. : Ok
Modules reading completed
Module checking
Sometimes if there is some discrepancy between alternate copies of the same defect list, this can cause symptoms like you suggest. I would try to write p-list form copy 0 to copy 1 and if it writes check if ID is possible now.
