Translator fault after head swap - ST1000LM024
Moderator: Garry_TS
avalanche
Postby avalanche » 21.07.15, 10:08
ST1000LM024 in with head failure. Heads were replaced successfully and HDD enters RDY.
Quite a number of firmware modules were unreadable reporting UNC or ABR on all heads. However increasing the read attempts in utility from the default of 102 to maximum of 255 allowed reading of nearly all modules. There were particular problems reading S-List to begin with
It is possible to read sectors, however there appears to be a translator issue - data in sector 0 is wrong, and other data the disk reads does not correspond to what would be expected in that sector. Reading parts of the MFT allow access to file entries, but opening the files they nearly all have the incorrect header. RAW recovery provides good files.
Perhaps one of the defect lists is not correctly being loaded? (S-List)
Terminal output below from power on.
Thanks,
A
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
DDR size detected = 16MB
*PAUNI_L2958*PA VID=0011 PN=000D Rev=0001- PA_LSI2958 Found
*PAUNI_L2958*PA VID=0011 PN=000D Rev=0001- PA_LSI2958 FoundU
S_0SO_1
SPU@23C,5060mV
IS=3
CLA ..36/65
HO..OK
HO RPM=3263 OK
AC 780
ST..Skip..OK
mS1 00000003
GT:406
SC(L):4100/16
BE.N:28
LD..OK
SK C: 7747 H:0
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x1B
ResoTable Loaded. Rev:0x01
Bump Limit Loaded. Rev:0x01
RRO1xTable Loaded. Rev:0x01
Fw Active 00
Ovly loaded to 0x00014D00
Ovly loaded to 0x1002DF60
FdtTable Loaded. Rev:0x02
| 17 | SLIST | 4 | 0 | 0 | 5B04 |
| 17 | SLIST | 4 | 1 | 0 | 1140 |
| 17 | SLIST | 4 | 2 | 0 | 1140 |
Unknown file id 384
Up MC
PwrOn RRO1x @ H0
Table) cos = -711680, sin = 496640
Coeff) cos = -35792, sin = 50008
DiskSlip : 122 [SrvTrk]
DiskSlip : 131 [SrvTrk]
0. phs diff 1 [wedges] Table) 155, coef) 154
PwrOn RRO1x @ H2
Table) cos = -716544, sin = 489472
Coeff) cos = -30592, sin = 34175
DiskSlip : 129 [SrvTrk]
4. phs diff 0 [wedges] Table) 156, coef) 156
TgtCyl: 832
Hd: 2 Zn: 0 Avg.:- 229
TgtCyl: 263568
Hd: 2 Zn: 1 Avg.: 1045
SVCAL(0080,0000)-->PASS
RecordValid Fail : 0406E47D 0007E41D
ENG>| 152 | ZONHEAL3 | 64 | 0 | 0 | 5B04 |
[INIT_ATWH_V2 REV:0008 GRP:1]
RdyTm = 15764986 us
EPOK
mS1 00000003
SK C:155464 H:0
SC(U)..4100/80
UD..OK : 80
PK_4 C: 9 H:0
healing Enable 003C 001E 0000 001E
cuumaytinh
Re: Translator fault after head swap - ST1000LM024
Postby cuumaytinh » 06.10.15, 20:25
you can used: rebuild S-List From T-List . And ReBuild T-List From D-List. in the menu .
Turn off and on Power. and try again.
Return to “Spin Point”
