Hello All,
Im trying Segate F3 drive with '' No HOST FIS-ReadyStatusFlags 2002B001 '' Error
Its segate ST500DM002 , FW KC48.. Im getting T..
Trying solution as mentioned https://www.youtube.com/watch?v=jWjPARPwBdk
but continuously getting LED:000000BC FAddr:00004264 error.. like below.. Can anybody tell me whats this mean /
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/
F3 T>V1
Re: LED:000000BC FAddr:00004264
what is the SIM error you get, if you get one?
check PCB is original, check settings of media cache also
Hello ,
Im getting this error..
Rst 0x10M
Servo Processor Is Reset.
Spin Up
FAIL Servo Op=0100 Resp=0003
ResponseFrame FFFF 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF
ResponseFrame 2EB0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
PCB is original .. {Check settings of media cache also means throgh Edit HDD ID ? } Not getting entry to Edit HDD id..
Rst 0x10M
Spin Up
Sorry - the symptoms here suggest heads cannot read. If PCB is original, I suggest you read ROM and adjust head map to test individual head (try with 0 first) .
I think it may be possible that heads are failed. Does the spindle shut down on No HOST error ?
Hello sir,
thanks for suggestions
Here are test results -->
Test : Read ROM
Reading ROM to profile folder
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\F3 Arch (common)\KC48 TEST\Data\ROM\
File : ROM.bin
Error : DT ID 15 is not found!
Head Map Test shows--->
SetKey error!
start time 7/15/2015 11:23:33 AM
finish time 7/15/2015 11:25:11 AM
I think its confirm head problem..
- VaibhavS
Test : Read ROM
File : ROM.bin
SetKey error!
- VaibhavS
