I have Newer model of wd my passport ultra USB 2.5" hdd.
Model no. is wd15nmvw-11av3s2. It is detected family is Shrek LT 2.5"
While reading the only pcb / Only rom it gives Head map check sum error
and Module ID 47 reading error Data request error VSC Command sending error Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Techno mode key
Debug Stop Code......................... : DEBUGSTOP OS TASK UNSAFE TIMEOUT
ROM version............................. : 21.04G
ROM generation.......................... : 21.04G
Link table version...................... : NA.28.
Consolidated ROM version................ : 00210004
ROM Modules:
Modules directory address............... : 318 299
SA defects assigned..................... : 2
Head Map Reading Error.................. : Head map check sum error
ROM Firmware version.................... : 00210004
Read ROM modules
Into file............................... : <HDD Profile>\Data\ROM
Module : 0A............................. : Ok
Module : 0B............................. : Ok
Module : 20B............................ : Ok
Module : 30............................. : Ok
Module : 47............................. : Module ID 47 reading error Data request error VSC Command sending error Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 0D............................. : Ok
Module : 4F............................. : Ok
is it rom corrupted?
The hdd giving clicking noise. Is related to rom?
Head map check sum error - WD15NMVW-11av3s2
Thanks,
Amit Shah
Arihant Data Recovery, India
Amit Shah
- datasolution
- New user
Re: Head map check sum error - WD15NMVW-11av3s2
Dear amitbhai,
can you access sa.than regenerate module 47.and rewrite it.
This model should have 7 heads. The log shows that it has 1 switched on head. Module 0A is head map module.
What is the log with PCB attached to HDD? Does heads knock and spindle shut down with HDD connected?
It has Head problem. Replaced the head from 2Tb hdd and issue resolved. Thanks,
Thanks,
Amit Shah
Amit Shah
