Clicking Seagate Momentus 750GB
profix
Postby profix » 07.05.15, 08:24
We have a 750GB Seagate Momentus 2.5" hard drive that clicks when powered.
When the complete drive is first powered on, the BSY registers lights up. After hearing three clicks from the heads, the registers change to DRD DSC. When I try to "Reread HDD ID", the BSY DRD DSC lights up, and no model, serial or firmware is detected. The BSY DRD DSC registers remain lit forever
When in terminal and powered on, terminal records the following output.
EarlySpinup Enabled
Rst 0x10M
ExecuteSpinRequest
LED:00000067 FAddr:00380338
If I'm quick I can get a brief terminal prompt:
EarlySpinup Enabled
Rst 0x10M
ASCII Diag mode
F3 T>
Input_Command_Error
F3 T>
ExecuteSpinRequest
Log:
Switching HDD power supply ON
Model by ID............................. : <HDD ID NOT READ>
Tech Key...
Error starting command "En Tech" (Drive is not ready)
Terminal : error detecting HDD terminal baud rate
Re: Clicking Seagate Momentus 750GB
Postby AJ2008 » 13.05.15, 11:57
Heads seem bad - you should confirm this is the case then replace them.
profix
Postby profix » 18.05.15, 02:03
I've mapped out the system heads in ROM using Physical remap (logical is not supported on this firmware). Also I've set the "Max heads" in "SAP control flags" to "0".
My problem is I can't get passed the checksum error that results from the head remap.
Flash boot code checksum failure!
SEA4 Boot ROM 2.0 (03/24/2009)
Copyright Seagate 2009
Postby AJ2008 » 18.05.15, 09:58
You ROM is damaged, you need to revert back to the original ROM you saved then try it again
