Wd USB 3.0 Detected but shows error code 4f10
houman_2h
Re: Wd USB 3.0 Detected but shows error code 4f10
Postby houman_2h » 21.11.14, 06:24
pclab wrote:Today I got the same error, after a PCB swap...
I'll try your suggestions.
An answer from ACE support would also be great...
Edit: The paper under the MHA didn't solved...
You select family manually
Postby AJ2008 » 21.11.14, 10:54
If shorted properly family will autodetect
Ardi
Postby Ardi » 25.11.14, 00:55
in Firebird LT Hotswap will NOT work , we can't stop motor or can't standby mode.
Short point in E47 not work.
Arihant
Postby Arihant » 28.11.14, 16:58
short read channel and e47- Ground is not working.
is it related to 5c module?
Thanks,
Amit Shah
Arihant Data Recovery, India
