Hello everyone,
this is my first post.
I was wondering if there is a criteria in selecting the right Sata PCB, compatible with that one USB.
For example I have this drive usb: WD5000BMVW-11AJGS0. PCB: 2060-771961-001 REVA.
To choose the right PCB what I should look?
Thank you very much in advance for any hint or advice.
How to select the right Sata PCB compatible with the one USB
Re: How to select the right Sata PCB compatible with the one
You will need 771959 from a HubbleLT ( WD5000LPVX-22V0TT0 ).
You will need to create some list or table of cross compatible boards, you will need it often
Thank you very kind AJ2008
AJ2008 wrote:You will need 771959 from a HubbleLT ( WD5000LPVX-22V0TT0 ).
dear AJ
what about WD500BMVV-11GNWS0
it is not usb3- i think the port is micro USB.
is this SATA PCB fixing on it:
771672
771672 - this is SATA PCB from Mariner series. This is compatible with GNWS with native PCB codes of 701675
