Hi there,
I need module 6F for a
WD6400BEVT-60A0RT0 Firmware 01.01.A01
ROM Firmware version 001300CB
I have
ROM Firmware version 0014001B
and module size is not matching
thanks a lot !
Need module 6F - WD6400BEVT-60A0RT0
Re: Need module 6F - WD6400BEVT-60A0RT0
6F is not important, also it is usually identified with some header error.
thanks for the reply AJ2008
somebody tell me the same on hdd guru.
Do you think that those 2 disks are compatible enough to swap pcb ?
or hot swap ?
(original post here : http://forum.hddguru.com/viewtopic.php?f=11&t=28685)
or hot swap ?
If module sizes are different then you cant hotswap, but if they are the same then it is ok. PCB change and change heads between these also would be fine.
What is problem with the drive?
Originaly, seems to be slower and slower, windows make f***g scandisk everytime.
Further, no access at all (scandisk says unrecoverable errors)
I have access to SA, backup everything with errors. Here is the log wher errors are :
When I try DE, partition table is empty, and ERR UNC appears on scan
What I try :
Module 2E : write copy 1 over copy 0 : ok
Module 32 : write copy from another disk (not same FW)
Original WD6400BEVT-60A0RT0-01-01A01 FW 001300CB
Implanted WD6400BEVT-80A0RT0-01-01A01 FW 0014003R
Translator regeneration
Here are errors in SA structure test :
006F CS error (cs value 00000000)
2045 CS error (cs value FE28F2D1)
2043 Header error (size 450)
2044 Header error (size 450)
for 2043 to 2045, i rewrite module from file (sabackup of original drive) and recheck, and is ok.
Head tests are ok on several cyl.
Code: Select all
Module : 32............................. : Module 0032 reading error ABA 2837 reading error - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module : 32............................. : Module 0032 reading error ABA 235541 reading error - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module : 2E............................. : Module 002E reading error ABA 22698 reading error - Device Error Detected: "DISK ECU UNSAFE ERROR"
Physical read error C/H/S: -231/0/59 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Cyl -231; Head 0........................ : Break
Physical read error C/H/S: -232/0/909 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Cyl -232; Head 0........................ : Ok
Physical read error C/H/S: -253/0/134 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Cyl -253; Head 0........................ : Ok
Physical read error C/H/S: -253/1/113 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Cyl -253; Head 1........................ : Break
What I try :
Code: Select all
002D: 0 : Dr : 22239: 450:Yes :Error: Ok : 6171BFD3 :00020004:Debug Log
002D: 1 : Dr : 22239: 450:Yes :Error: Ok : 6171BFD3 :00020004:Debug Log
002E: 0 : B : 22689: 450:Yes :Error: Ok : 7266852E :00020004:Loaded part of microprogram code
002E: 1 : B : 22689: 450:Yes :Error: Ok : 7266852E :00020004:Loaded part of microprogram code
006F: 0 : B : 23412:2144:Yes : Ok :Error:00000000/F64E8F26:AOZ30000:Loaded part of microprogram code
006F: 1 : B : 23412:2144:Yes : Ok :Error:00000000/F64E8F26:AOZ30000:Loaded part of microprogram code
Module 32 is pending list, it is list of sectors identified as bad and pending relocation. If this list is bad it could suggest many errors which may be symptom of some other problem.
If 32 is bad, you will not reach surface, only ABR errors.
You have option to try relocate 32 to unused area of disk, then write with donor then clear it. Also, you can disable this process totally but only when #32 is operational. You can clear manually by modification of module 02.
Personally, for me, your best option is hotswap if you have similar drive for hotswap
Here we are with hotswap...
it is mariner, don't listed in viewtopic.php?f=35&t=7086 so made procedure from pdf doc (even if mariner is ROYL)
Patient Microjogs :
0x0B3D
0x0B2A
0x0B43
0x0B77
Donnor Microjogs :
0x0BCF
0x0BAD
0x0BA3
0x0B6E
Not so bad, isn't it ?
So...
- Write Module ID=01 and restart the drive : ok
- after restart HDD fail to identify, but functionality for module recording by ID will be available : only ROM module writing is available
- write remaining modules : rom modules, ok, but others ?
- sleep command is not present (only standby)
- force normal mode on donnor : LDR needed
- try to force write module : 02 and 03 ok, 04 fails...
- try with or without average microjogs, idem...
For safety, I write back all modules from donor to donor...
I'm trying ROYL process now...
Patient Microjogs :
0x0B3D
0x0B2A
0x0B43
0x0B77
Donnor Microjogs :
0x0BCF
0x0BAD
0x0BA3
0x0B6E
So...
And it fails.
Same thing happen.
drive is ready after hotswap, but unc errors.
you must be right on Module 32.
Your advice is to relocate 32 on patient ?
Same thing happen.
Hot swap give me access to partition table, but i'va got errors when i access to them...
root dir is not valid operation aborted
what do you think ?
what do you think ?
Maybe you didnt transfer translator information and you could have data shifts. Can you check MBR data at sector '0' - this will allow you to check if HS works correctly, allows checking to see if surface can be read, and allows you to manually verify MBR data is good.
thanks a lot.
it'w out of office time for me now, but I will try this on moday.
cheers,
cheers,
hi AJ!
can you explain the procedure of hot swap.
i reviewed ace manual for WD hard disk's but i couldn't understood what is hot swap and the steps of doing this method.
i have WD500BEVT that is not detect, somebody advised me to do hot swap,i searched but i couldn't find any article in this forum.
appreciate if you reply me.
@rezafarah : I copy/paste here the hotswap method worked for me :
@AJ : I have access to 0 Sector. But if I try some other sectors (max ie), I hear heads and drive hangs.
Is it a good idea to regenerate translator after hotswap, or not ?
according to colors, I only put this modules for hotswap :
31,36,03,40,41,42,43,49,4A,4D,50,51,52,53
thanks
- boot a donor drive
- put it to sleep
- swap the pcb to the bad drive without powering the drive off
- Do recalibration
- read the modules of the bad drive that way.
- When you have the necessary modules like translator, etc ... you copy those to the donor drive with his own pcb
- power of/on donor
- put it to sleep
- do recalibration
thanks
thank you hddr49.
I try again, with all modules :
partition is now empty again, don't have any access...
make me crazy this one
