Dear Guru
hi
these days I am involved with a WD6400BEVT-75A0RT0 (family:Mariner) which suffers from Rom problem .
the hdd doesn't spin up , after changing the PCB with a same one from same family and writing Rom from same family ,
I am able to read 95% of SA Modules .
I tried to rebuild the ROM and ROM's Modules , but unfortunately i did not succeed .
one of my friends told me that for this family we are not able to do ROM rebuilding .
now how can I recovering the data from this hdd ??
waiting for soonest reply
best regards
Mojtaba Morady
Mariner Family Rom Rebuilding Procedure
- mojimorady
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
Re: Mariner Family Rom Rebuilding Procedure
You can restore ROM from #109 and then write ROM mods from similar donor. Make sure head mapping is the same in resources you write.
- mojimorady
dear AJ2008
thank you for your reply
1) I could read the Mod#109 before , now how can I restore ROM using that Module ??
2) I also need Rom Modules resources for this hdd ?
can u help me in both of above things ??
best regards
Mojtaba Morady
best regards
Mojtaba Morady
Mojtaba Morady
You need to generate ROM from 109 through utility, then write in kernel mode, after repower write donor ROM modules.
Trying to write complete ROM will likely damage the ROM.
I can help over skype if you have it?
- mojimorady
hi AJ2008
I have skype account
My skype ID is : mojimorady
best regards
best regards
Mojtaba Morady
All solved
- mojimorady
hi
lots of appreciation to AJ2008
the case was solved
the case was solved
Mojtaba Morady
- mojimorady
AJ2008 wrote:All solved
thank u so much !!!!
Mojtaba Morady
