I have a Samsung HD502HJ hard drive
P / N: HD502HJ / B
Rev: A
Frm: 1AJ100002
he turns five seconds and it stopped and the PC 3000 can not detect.
I took voltage PCB and compare with other PCBs, there are the same voltage.
Can you help me Please
thank you
cordially
Samsung HD502HJ turns five seconds and it stopped
Moderator: Garry_TS
PC-3000 Express
PC-3000 SSD
PC-3000 Flash
PC-3000 SSD
PC-3000 Flash
Re: Samsung HD502HJ turns five seconds and it stopped
Probably is some problem with Alist or SMART.
After it stops, can you send soft reset (or maybe several) and does it show ID then?
I can not see HDD ID
Model: HDD ID has not been read
serial:
firmware:
Capacity: ,49 MB (1000)
In Termial: LED 1A04
Thank
serial:
firmware:
Thank
AJ2008 wrote:Probably is some problem with Alist or SMART.
PC-3000 Express
PC-3000 SSD
PC-3000 Flash
PC-3000 SSD
PC-3000 Flash
There is option to solve this within utility. If you search this forum for LED 1A04 you should find more info on it
