Seagate ST9500325AS not detected under Windows hard drive
Hoang21
Postby Hoang21 » 07.04.14, 14:27
I have a Seagate ST9500325AS spins but not detected under Windows .
PC 3000 gives the message:
HDD family detecting...
Family ID: 3C
Selected family......................... : 3C, Wyatt
Model by ID............................. : ST9500325AS
Loading default settings!
Then press OK!
Tech Key...
Drive not ready
Access violation at address 40004B3C in module 'Vcl50.bpl'. Read of address 53203A18
In the terminal displays:
LED:000000CC FAddr:00259A4D
Help me
thank you
PC-3000 Express
PC-3000 SSD
PC-3000 Flash
Nick_TS
Re: Seagate ST9500325AS not detected under Windows hard driv
Postby Nick_TS » 09.04.14, 15:25
Hello Hoang,
Try to isolate spindle motor contact and reach terminal. Then you have to make backup and try to regenerate translator.
Hoang21
Postby Hoang21 » 19.05.14, 09:54
Hello Dima
I used Tests -> User commands -> Translator regeneration
Log in:
Executing user command ..................: Translator regeneration
Terminal: reply timeout error
LED: 000000CC FAddr: 0025AF5B
Thank
Dima wrote:Hello Hoang,
PC-3000 Express
PC-3000 SSD
PC-3000 Flash
Postby AJ2008 » 19.05.14, 10:28
Hoang21 wrote:Hello Dima
Log in:
Thank
You cant regen translator while isolated because with PCB detached SA cant read. You need to reach T> after isolated, then send spindown command before reconnecting PCB to HDA. Only then you can reach SA
Hoang21
Postby Hoang21 » 20.05.14, 17:05
Thank you IN 2008
I tried to do as you say
In Terminal shows:
F3 T>/
F3 T>m0,6,2,,,,,22
DiagError 00005014
F3 T>
RW cmd 002F req = 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 00 00 A0 E1
opts = 00000000
RW Err = 84150180
In Log:
Tech Key...
Drive not ready
Executing user command.................. : Translator regeneration
ASCII Diag mode
F3 T>/
F3 T>m0,6,2,,,,,22
DiagError 00005014
F3 T>
I use DE so it displays error message
Thank
PC-3000 Express
PC-3000 SSD
PC-3000 Flash
