Hi everybody,
this drive is starting with normal noise, not recognised (by OS and PC3K), led is on, not flashing. After long time, led starts flashing, drive is recognised by OS with right parameters, right size, partitions (2) are shown too, but no reads (winhex or similar). PC3K does not see it anyway.
Any idea (before opening it) ?
BTW, what SATA card is suitable to be used ?
Thanks in advance
Max
WD5000BMVV 11GNWS0 USB drive
Re: WD5000BMVV 11GNWS0 USB drive
This is Marn 5_4K drive. You can transfer ROM to Mariner PCB.
Thanks for the quick reply! Can you give me some model numbers / wd code series so I can search better my inventory? Thanks again
Tell me the PCB code on your PCB, should be something like 2060-701675-004. The important part is highlighted bold.
Probably you will need 771672 (2060-771672-001) from mariner (WD5000BEVT-00A0RT0)
Sorry for delay!
my card is marked 2061-701675-604
This is what you need
AJ2008 wrote: 771672 (2060-771672-001) from mariner (WD5000BEVT-00A0RT0)
