Cant repair and recover data from Toshiba 3TB
stathopon
Postby stathopon » 04.11.13, 16:33
How can i solve this difficult issue?
rezafarah
Re: Cant repair and recover data from Toshiba 3TB
Postby rezafarah » 04.11.13, 17:22
hi
can you explain what is your problem exactly.
i mean the hdd exact model and the problem that you face?
stathopon
Postby stathopon » 06.11.13, 11:39
I have an Sata Toshiba P/N 9F14318, Capacity : 3.0TB drive and after it is fall down from 15cm (desk to floor) it is clicking..
iam trying to take my files..can you help me?
rezafarah
Postby rezafarah » 06.11.13, 20:04
if it is clicking and not detecting in pc3k so i think you need to find a donor hdd to change the the patient hdd.
stathopon
Postby stathopon » 07.11.13, 20:20
what to change??? a donor HDD?? what do you mean?? do you mean to change the head of platters??
rezafarah
Postby rezafarah » 08.11.13, 19:53
yes sir.
i mean change the patient heads with donor head.
the heads of your patient hdd that falls,should change with the same hdd that have ok heads.
stathopon
Postby stathopon » 12.11.13, 19:34
Okey, i got it ...every situation here needs to change the heads....
Do i need HEADS from the same donor HDD like patient HDD ? ? ?
rezafarah
Postby rezafarah » 13.11.13, 09:01
yes.
the model and firmware should be the same.
lcoughey
Postby lcoughey » 13.11.13, 17:29
Why does it come as a surprise that a dropped drive might need donor heads? There is a good chance that the damage is fatal and it would be well advised to inspect the drive in the clean room before ordering a donor drive for parts.
stathopon
Postby stathopon » 15.11.13, 19:18
What to do in a clean room? just to move the heads off and put it back ..and will work?
Where to buy clean box?
Postby AJ2008 » 18.11.13, 11:01
stathopon wrote:What to do in a clean room? just to move the heads off and put it back ..and will work?
You will probably have more luck in outsourcing it, at least in the short term until you have required facilities and experience to take these on yourself.
stathopon
Postby stathopon » 23.11.13, 01:21
Thank again for your fast reply...so your suggestion is to send it outsourse for beginning?
How can i learn more about DR 8) ? any wiki or pdf books for reading? do y advise any?
pclab
Postby pclab » 26.11.13, 13:57
You can try to do head swaps on your own HDD's and pratice with them.
When you feel confident, you can work on client's hdd's.
Return to “Toshiba native”
