I need to recover data from a Seagate ST2000DM.
Hdd do not knock, i can ear motor startup end it go to ready, but utility cannot recognize it.
I see follow on Terminal report :
Boot 0x40M
Spin Up
TCC-0018[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0018
(P) SATA Reset
MCMTFileHandler: EXCEPTION: Failed MCMT read request
MCMainPOR: EXCEPTION: SIM aborted prior to MCMT read
MCMainPOR: EXCEPTION: POR Failed General
MCMainPOR: Feature Disabled...
I have Terminal access with CTRL-Z and i trie Smart Clear and translation regeneration. Either end well, but nothing change for ID problem.
Some one can help me ?
Thank you
Seagate ST2000DM - No ID
Re: Seagate ST2000DM - No ID
Maybe your problem deals with media cash.
Try to reset media cash log.
Sorry but how i can reset media cash log ?
Tnks
Tnks
In menu Tests->Service Information->Work with service area->Edit HDD ID
switch off tick at "Media Cashe".
Tnks Dima for your answer, but my problem is that i cannot switch off tick at "Media Cashe", because when i try Tests->Service Information->Work with service area->Edit HDD ID i have follow error :
Error Starting Command "En Tech" (ABR)
and DRD, DWF, DSC and ERR Status Register LED, light on.
For clear my situation, follow full terminal log :
(After Power on, i have follow terminal log)
Boot 0x40M
Spin Up
TCC-0015[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
Spin Up
TCC-0015
(P) SATA Reset
PowerState = IDLE1
PowerState = IDLE2
(After i try to switch off tick at "Media Cashe", i have follow terminal log)
HighPowerMode
TCC-0016Status 0001 Req 0006
Dither
TCC-0016
Dither
TCC-0017
Dither
TCC-0017
Dither
TCC-0017
Dither
TCC-0017
After this, for have again ready status, i need to send a Software Reset, but after if i try any command or operation i have always Error Starting Command "En Tech" (ABR) error.
Someone can help me pls ?
Thank you.
Boot 0x40M
Spin Up
Trans.
Rst 0x40M
Spin Up
TCC-0015
(P) SATA Reset
PowerState = IDLE1
PowerState = IDLE2
HighPowerMode
Dither
TCC-0016
Dither
TCC-0017
Dither
TCC-0017
Dither
TCC-0017
Dither
TCC-0017
Thank you.
If you can't write modules, then problem may be caused by damaged heads.
I have this same issue after a power surge.
Anyone been able to fix this?
Please share your solution.
Tnks
Tnks
Thanks,
Amit Shah
Arihant Data Recovery, India
Amit Shah
ok , I share my solution . you must write sys file 346 .
