I have Western Digital-SATA 2.5-
WD10TPVT-00U4RT1-
1000 GB
It was clicking then stops from spinning, I changed the heads from New Donor to the damaged drive, it did not work, same behavior.
Now I put the native heads (that was originally in the damaged drive) into donor drive, it worked properly. Strange.
I need Loader, may be it can solve the problem, because it is not head problem.
Model: WD10TPVT-00U4RT1
Rom Info:
ROM:
ROM version............................. : 08.06B
ROM generation.......................... : 08.06B
Link table version...................... : 02.07.
Consolidated ROM version................ : 00080006
If any idea please help.
Thank you
WD10TPVT-00U4RT1 Loader
- RescueDRL@gmail.com
Re: WD10TPVT-00U4RT1 Loader
here is mod 11 from 0008000C version of WD10TPVT-00U4RT1 i dont know if that helps.
