Model : TOSHIBA MK1234GSX
Serial : Z64TT2KJT
Firmware : AH008B2
Capacity : 111.79 GB (234 441 648)
gets glist error.
cant erase glist
can read plist
params
zone table
etc
someimes can read sectors
reads better in utility or no error retry
G-List reading error.................... : G-List read error; Device Error Detected 51/19 (AMN;<bit3>;INF)
CP Avalable............................. : 33,34,44,56,91,92,93,94,95,97,98,9A,9B,9C,9F,A2,A6,A7,AA,BB,C1,CC,DD
Recalibration attempt ...
Ok
Defect list reading
Table................................... : P-List
File.................................... : <HDD Profile>\Defects\PList.chs
Defect list reading
Table................................... : G-List
File.................................... : <HDD Profile>\Defects\GList.lba
Ok
Defect list reading
Ok
Clearing G-List
Ok
Clearing G-List
Ok
Defect list reading
Ok
TOSHIBA MK1234GSX - glist error
Re: TOSHIBA MK1234GSX - glist error
thanks for the reply...
its been 5 days.
this is data recovery.
Its time sensitive.
The customer needs an answer
do you guys have a solution for this problem - yes or no ?
glist is bad
erase glist does not return an error
but glist is still corrupt.
its been 5 days.
Its time sensitive.
glist is bad
and yes i can read the zone table to the mpu is working...
Re: TOSHIBA MK1234GSX - glist error - fixed
roustam suggested that I swap heads.
I did.
Then it erased the glist!
hooray
imaging now
head 0 is slow
thanks
I did.
hooray
imaging now
head 0 is slow
thanks
I recently had one of these Toshibas with glist error that would not let me clear it out. It gave errors when trying to clear. The CPs were all good- so I backed them up.
I got a donor and backed up resources from donor (ROM, CPs, etc). Be careful to put donor's resources in different folder than customer's.
I moved customer's ROM to donor PCB. In Toshiba utility, I then was able to clear G-list and SMART.
I then repowered and moved customer's CPs back to customer drive (keeping the donor PCB with customer's ROM attached to customer drive).
I was then able to read all the data.
MKS please can you explain what you've done precisely, it seems some steps are missing ?
He moves ROM to donor PCB and clears GLIST there
GLIST stored in PCB not SA
Ok thanks.
In my case, my tests have killed heads...
I can see now many microscopic scratches on one surface (when I got it heads were on the platters and prevent motor from starting).
MKS wrote:I recently had one of these Toshibas with glist error that would not let me clear it out. It gave errors when trying to clear. The CPs were all good- so I backed them up.
Can you tell me how to move rom in Toshiba utility ? i cant see in mine Pc3k i really appreciate
This moving of ROM refers to transfer of physical ROM chip with rework station
AJ2008 wrote:This moving of ROM refers to transfer of physical ROM chip with rework station
thanks
