hi guru
i have a hdd as follow :
HITACHI 320gb 2.5" SATA
MODEL : HTS723232L9SA60
when i connect it to PC3000 and power it on it starts spinning and after 3 4 seconds it shows ready state
when i enter hitachi window and select proper family from custom family and press utility start button the following was shown :
Loading data for correction of HDD family handling settings from section MEM_P
Loading data for correction of HDD family handling settings from section HTS7232L9
Selected family......................... : CUSTOM
i should mention that the hdd was not detected with PC3000 at all
lots of appreciation for your soonest reply
mojimorady
HTS723232L NOT DETECT !!
- mojimorady
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
Re: HTS723232L NOT DETECT !!
Run SA test please, and post results here. It is better to add it in *.rep format.
- mojimorady
dear igor
my kindest regards to you
Module RSVD Copy 0...................... : Ok
Module RSVD Copy 1...................... : Error
Module RESF Copy 0...................... : Ok
Module RESF Copy 1...................... : Error
Module RESF Copy F...................... : Ok
Module RAM0 Copy 0...................... : Error
Module RAM0 Copy 1...................... : Error
Module RAM0 Copy F...................... : Error
Module OVR0 Copy 0...................... : Error
Module OVR0 Copy 1...................... : Ok
Module OVR0 Copy F...................... : Error
Module RESF(1) Copy 0................... : Ok
Module RESF(1) Copy 1................... : Ok
Module RESF(1) Copy F................... : Ok
Module PTCH Copy 0...................... : Ok
Module PTCH Copy 1...................... : Ok
Module PTCH Copy F...................... : Ok
Module CNS1 Copy 0...................... : Ok
Module CNS1 Copy 1...................... : Ok
Module CNS1 Copy F...................... : Ok
Module RWCN Copy 0...................... : Ok
Module RWCN Copy 1...................... : Ok
Module RWCN Copy F...................... : Ok
Module ZONE Copy 1...................... : Ok
Module ZONE Copy F...................... : Ok
Module PTRT Copy 0...................... : Ok
Module PTRT Copy 1...................... : Error
Module PTRT Copy F...................... : Ok
Module SRVP Copy 1...................... : Ok
Module SRVP Copy F...................... : Ok
Module SRVM Copy 0...................... : Ok
Module SRVM Copy 1...................... : Ok
Module SRVM Copy F...................... : Ok
Module CHNL Copy 0...................... : Ok
Module CHNL Copy 1...................... : Error
Module CHNL Copy F...................... : Ok
Module IDNT Copy 0...................... : Ok
Module IDNT Copy 1...................... : Error
Module IDNT Copy F...................... : Ok
Module SN00 Copy 0...................... : Ok
Module SN00 Copy 1...................... : Error
Module SN00 Copy F...................... : Ok
Module MISC Copy 0...................... : Ok
Module MISC Copy 1...................... : Error
Module MISC Copy F...................... : Ok
Module ICES Copy 0...................... : Ok
Module ICES Copy 1...................... : Error
Module ICES Copy F...................... : Ok
Module MLBA Copy 0...................... : Ok
Module MLBA Copy 1...................... : Error
Module MLBA Copy F...................... : Ok
Module QMCN Copy 0...................... : Ok
Module QMCN Copy 1...................... : Error
Module QMCN Copy F...................... : Ok
Module SMRT Copy 1...................... : Ok
Module SMRT Copy F...................... : Ok
Module PNID Copy 0...................... : Ok
Module PNID Copy 1...................... : Ok
Module PNID Copy F...................... : Ok
Module SMRA Copy 0...................... : Ok
Module SMRA Copy 1...................... : Ok
Module SMRA Copy F...................... : Ok
Module ABLP Copy 0...................... : Ok
Module ABLP Copy 1...................... : Ok
Module ABLP Copy F...................... : Ok
Module ABLD Copy 0...................... : Ok
Module ABLD Copy 1...................... : Ok
Module ABLD Copy F...................... : Ok
Module SSTL Copy 0...................... : Ok
Module SSTL Copy 1...................... : Ok
Module SSTL Copy F...................... : Ok
Module SERL Copy 0...................... : Ok
Module SERL Copy 1...................... : Ok
Module SERL Copy F...................... : Ok
Module SSST Copy 0...................... : Ok
Module SSST Copy 1...................... : Ok
Module SSST Copy F...................... : Ok
Module SKPO Copy 0...................... : Ok
Module SKPO Copy 1...................... : Ok
Module SKPO Copy F...................... : Ok
Module DCOT Copy 0...................... : Ok
Module DCOT Copy 1...................... : Ok
Module DCOT Copy F...................... : Ok
Module SRIF Copy 0...................... : Ok
Module SRIF Copy 1...................... : Ok
Module SRIF Copy F...................... : Ok
Module BULK Copy 0...................... : Ok
Module BULK Copy 1...................... : Ok
Module BULK Copy F...................... : Ok
Module ALTT Copy 0...................... : Ok
Module ALTT Copy 1...................... : Ok
Module ALTT Copy F...................... : Ok
Module DBGC Copy 0...................... : Ok
Module DBGC Copy 1...................... : Ok
Module DBGC Copy F...................... : Ok
Module OFDT Copy 0...................... : Ok
Module OFDT Copy 1...................... : Ok
Module OFDT Copy F...................... : Ok
Module RDMT Copy 0...................... : Error
Module RDMT Copy 1...................... : Error
Module RDMT Copy F...................... : Error
Module RELI Copy 0...................... : Ok
Module RELI Copy 1...................... : Ok
Module RELI Copy F...................... : Error
Module PSHT Copy 0...................... : Error
Module PSHT Copy 1...................... : Error
Module PSHT Copy F...................... : Error
Module OVR1 Copy 0...................... : Error
Module OVR1 Copy 1...................... : Error
Module SPRE Copy 0...................... : Error
Module SPRE Copy 1...................... : Error
Module PESD............................. : Error
Module MFGP............................. : Ok
Module SRST............................. : Error
Module FLOG............................. : Error
Module DUMP............................. : Error
Module ##01 Copy 0...................... : Ok
Module ##01 Copy 1...................... : Ok
Module ##01 Copy F...................... : Ok
my apperciation for your reply
mojtaba moradi
mojtaba moradi
Mojtaba Morady
Run reading SA modules using option "Composite reading"
Paste here log.
Paste here log.
- mojimorady
Dear Igor
accept my regards and also thank u for all your responses
as u told , i did what you said and the result is as follow :
Test : Reading modules
Reading modules to profile folder (composite)
Folder: C:\Program Files\ACE Lab\PC-3000UDMA\Bin\!Profiles\HITACHI-IBM\CUSTOM\hitachi - data tech\Data\Modules
Module RSVD............................. : Ok
Module RESF............................. : Ok
Module not read (RAM0)
Error : Device error detected (UNC)
Module RAM0............................. : Ok
Module not read (OVR0)
Module OVR0............................. : Ok
Module RESF(1).......................... : Ok
Module PTCH............................. : Ok
Module CNS1............................. : Ok
Module RWCN............................. : Ok
Module ZONE............................. : Ok
Module PTRT............................. : Ok
Module SRVP............................. : Ok
Module SRVM............................. : Ok
Module CHNL............................. : Ok
Module IDNT............................. : Ok
Module SN00............................. : Ok
Module MISC............................. : Ok
Module ICES............................. : Ok
Module MLBA............................. : Ok
Module QMCN............................. : Ok
Module SMRT............................. : Ok
Module PNID............................. : Ok
Module SMRA............................. : Ok
Module ABLP............................. : Ok
Module ABLD............................. : Ok
Module SSTL............................. : Ok
Module SERL............................. : Ok
Module SSST............................. : Ok
Module SKPO............................. : Ok
Module DCOT............................. : Ok
Module SRIF............................. : Ok
Module BULK............................. : Ok
Module ALTT............................. : Ok
Module DBGC............................. : Ok
Module OFDT............................. : Ok
Module not read (RDMT)
Module RDMT............................. : Ok
Module RELI............................. : Ok
Module not read (PSHT)
Module PSHT............................. : Error
Error : ModStg: composite reading impossible - reading error!
Module not read (OVR1)
Module OVR1............................. : Ok
Module not read (SPRE)
Module SPRE............................. : Ok
Error : Module not read (PESD)
Error : Module not read (SRST)
Error : Module not read (FLOG)
Error : Module not read (DUMP)
Module ##01............................. : Ok
Modules reading completed
lots of appreciation for your reply in advance
best regards
Mojimorady
best regards
Mojimorady
Mojtaba Morady
- paramagnetic
Since my issue seems to be similar I figured It may be better to Hijack this thread that seems dead instead of creating my own:
I have Hitachi HTS723216L9SA60
Original problem was clicking; with first set of new heads:
Drive spins
Does not click
Comes DRDY
When attempt ID, ABRT and fails.
When in utility cannot perform SA structure tests, nothing happens just sits.
NVRAM and ROM appear to be intact to me.
Rebuilt first donor, works.
Used second donor, same results.
Currently trying NVRAM adjustment after backing up all ROM and NVRAM from patient and donors...
Drive spins
Does not click
Comes DRDY
NVRAM adjustment will not help.
You need somehow to get copy of all crucial modules. If composite does not work well then maybe there is possibility to read each module with 'Ignore reading error' and see if there is possibility to manually rebuild it.
How many heads does the HDD have? If has 4 heads is possible to switch SA surface as I assume the SA surface(s) here are not so healthy.
Users browsing this forum: Bing [Bot] and 1 guest
