This Hard Drive has falled. Now it shows DRD DSC but sizzle a little and answer ABR at ID request.
I change heads but it doesn't helped at all (platters surfaces seems in good condition).
A lot of modules are broken, but maybe because Open module table isn't read. Here is Structure test :
Do you have an idea if something can be done with it ?
HDT722525DLA380 ABR Error
Re: HDT722525DLA380 ABR Error
What are the modules that can't be read?
SA structure test.zip --->
Loading data for correction of HDD family handling settings from section MEM_P
Selected family......................... : DLAT
Module not read (USAG)
Error : Device error detected (UNC)
Test : SA structure test
Module checking
Module RSVD Copy 0...................... : Error
Module RSVD Copy 1...................... : Ok
Module USAG Copy 0...................... : Error
Module USAG Copy 1...................... : Ok
Module USAG Copy F...................... : Error
Module PSHT Copy 0...................... : Error
Module PSHT Copy 1...................... : Error
Module PSHT Copy F...................... : Error
Module RDMT Copy 0...................... : Error
Module RDMT Copy 1...................... : Error
Module RDMT Copy F...................... : Error
Module RLBA Copy 0...................... : Error
Module RLBA Copy 1...................... : Ok
Module RLBA Copy F...................... : Error
Module CNSL Copy 0...................... : Error
Module CNSL Copy 1...................... : Error
Module CNSL Copy F...................... : Ok
Module RWCN Copy 0...................... : Ok
Module RWCN Copy 1...................... : Error
Module RWCN Copy F...................... : Ok
Module CHNM Copy 0...................... : Error
Module CHNM Copy 1...................... : Error
Module CHNM Copy F...................... : Error
Module SRVP Copy 1...................... : Error
Module SRVP Copy F...................... : Ok
Module SRVM Copy 0...................... : Error
Module SRVM Copy 1...................... : Error
Module SRVM Copy F...................... : Error
Module ZONE Copy 0...................... : Error
Module ZONE Copy 1...................... : Error
Module ZONE Copy F...................... : Error
Module PTRT Copy 0...................... : Error
Module PTRT Copy 1...................... : Error
Module PTRT Copy F...................... : Error
Module RAM0 Copy 0...................... : Error
Module RAM0 Copy 1...................... : Ok
Module RAM0 Copy F...................... : Error
Module OVR1 Copy 0...................... : Error
Module OVR1 Copy 1...................... : Error
Module OVR1 Copy F...................... : Error
Module SMRT Copy 1...................... : Error
Module SMRT Copy F...................... : Ok
Module MLBA Copy 0...................... : Ok
Module MLBA Copy 1...................... : Ok
Module MLBA Copy F...................... : Ok
Module SECI Copy 0...................... : Ok
Module SECI Copy 1...................... : Error
Module SECI Copy F...................... : Ok
Module SRIF Copy 0...................... : Error
Module SRIF Copy 1...................... : Error
Module SRIF Copy F...................... : Ok
Module SERL Copy 0...................... : Error
Module SERL Copy 1...................... : Error
Module SERL Copy F...................... : Error
Module IDNT Copy 0...................... : Error
Module IDNT Copy 1...................... : Error
Module IDNT Copy F...................... : Ok
Module DCOT Copy 0...................... : Ok
Module DCOT Copy 1...................... : Error
Module DCOT Copy F...................... : Ok
Module PTCH Copy 0...................... : Error
Module PTCH Copy 1...................... : Error
Module PTCH Copy F...................... : Error
Module ##01 Copy 0...................... : Ok
Module ##01 Copy 1...................... : Error
Module ##01 Copy F...................... : Ok
Module ##02 Copy 0...................... : Ok
Module ##02 Copy 1...................... : Error
Module ##02 Copy F...................... : Ok
Module ##03 Copy 0...................... : Ok
Module ##03 Copy 1...................... : Error
Module ##03 Copy F...................... : Error
Module ##04 Copy 0...................... : Ok
Module ##04 Copy 1...................... : Error
Module ##04 Copy F...................... : Error
Module PESD............................. : Error
Module SRST............................. : Error
Module SSSC............................. : Ok
Module SSCD............................. : Error
Module NVRC............................. : Error
Module PIDM is not found!
Module not created! PIDM
Module MFGP is not found!
Module not created! MFGP
Module checking
Nobody can help me ?
