module 2 unreadeable WD5000BMVV
eurlamp
Postby eurlamp » 19.12.11, 18:01
I've got a WD USB Passport WD5000BMVV and it can't read SA. It says module 02 is not found.
This is the report :
Techno mode key
RAM:
Zone allocation table................... : HDDs RAM reading error; unexpected error: Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM version............................. : 13.CCG
ROM generation.......................... : 13.CCG
Link table version...................... : 05.C9.
Consolidated ROM version................ : 001300CC
ROM Modules:
Modules directory address............... : FIXED
ROM Firmware version.................... : 001300CC
Service area:
SA dir reading.......................... : Device error detected
What can I do for recovering user's data?
François
dmarques
Re: module 2 unreadeable WD5000BMVV
Postby dmarques » 20.12.11, 10:48
It's not reading DIR module to load SA.
Can you explain what happened to that drive and what happens when you power it on.
eurlamp
Postby eurlamp » 07.01.12, 14:29
Finally I open the drive in cleanroom and there is a big circular scratch on the first platter so I stop investigation.
eurlamp
