How to make a com-port connection with WD USB drive
Postby ACE_Admin » 09.08.11, 15:06
As far as you can see from latest PC-3000 UDMA 4.7 change log , current WDC Marvell usb utility supports com-port connection.
This could help to reach the SA modules on WD drive, when hard drive is not identified by operational system.
Here is the connection for WD USB 2.0 drive:
Hard drive has 6 pins in one row. So, PC-Toshiba adapter is connected, and three pins are left free. Please check the picture above.
Here is the connection for WD USB 3.0 drive
Hard drive has two rows of 6 pins. PC-TOSHIBA adapter has to be connected onto top row. The drive position has to be same, it is on picture.
As soon, as new manuals for PC-3000 WD USB utility will be ready, it will appear in personal update box, manuals Western Digital section.
Re: How to make a com-port connection with WD USB drive
Postby ACE_Admin » 18.08.11, 10:33
PC-Toshiba adapter scheme
Postby AJ2008 » 07.09.11, 14:16
What operations can be made through com-port in WD?
Can be used to assist data recovery? or confirm diagnostic problems?
tea
Postby tea » 09.09.11, 10:21
mee too
thank you
Postby ACE_Admin » 25.10.11, 14:18
Well, com-port is used to transfer common ATA commands. If the drive has healthy SA and there are no hardware problems you could even read user data from it.
Continuum
Postby Continuum » 15.11.11, 05:28
I did not seem to get a PC-Toshiba adapter in the box (either of the 2 I bought)
Should we have gotten one of these?
einstein9
Postby einstein9 » 15.11.11, 08:02
Continuum wrote:I did not seem to get a PC-Toshiba adapter in the box (either of the 2 I bought)
use cd-rom audio cable
Continuum
Postby Continuum » 16.11.11, 07:12
thanks, but were we meant to get one, or do we have to make one?
tim
Postby tim » 16.11.11, 07:52
Connected the wd USB drive with com-port and get access to SA, model and serial number correctly, but not by USB and OS. How to mirror the drive by com-port? Tried data extractor, could not detect by port 1 and 2, but no USB port. Also, can I use heads map to mirror drive by USB port? Thx
Continuum
Postby Continuum » 17.11.11, 05:54
Ok Worked out the com port connection, but I cannot seem to image the drive through DE either. i can see sectors through the utility (sector editor) but not through DE. Is there a trick to this?
pclab
Postby pclab » 19.07.14, 13:38
No more info about this possibility?
What can we do with terminal? Can someone do a manual?
Or is it already on ACE manual (I can't see it there...)
Postby AJ2008 » 21.07.14, 10:23
With terminal its possible to access SA over serial. also its possible to read sectors over serial but at serial speed, also will read encrypted.
I sometimes use serial to access utility and read SA before SATA conversion to allow easy restore of ROM without soldering (I prefer this method since Shasta models with internal ROM)
pclab
Postby pclab » 21.07.14, 15:20
Hi AJ
But how to use it?
Is there anything on the manual about this? Where can I find more info?
Because I have a USB drive to work with, and if I could get this to work without the need of a PCB, ROM swap, etc, it would be great.
Postby AJ2008 » 21.07.14, 15:29
Ill contact you at skype
oldman
Postby oldman » 13.10.14, 06:32
Seem that I can not find this USB utility in UDM-E Ver 5.8, where is it?
Thanks.
Phil
Return to “WD USB”
