MK3265GSX problem
misa
MK3265GSX problem
Postby misa » 30.08.11, 10:45
I have patient Toshiba MK3265GSX.
When power on the drive calibrate slowly, but good drive ID and I can build head map on DE.
When I try to copy data, I have read error (I try on many part of surface).
I changed head with same result
I changed PCBA + FW with same result
I clear Glist but same result
Anyone can help me?
Igor
Re: MK3265GSX problem
Postby Igor » 30.08.11, 11:14
What error of reading do you get?
have you tried to read surface in all reading modes (UDMA66, UDMA33, with HW retries and etc.)?
Postby ACE_Admin » 31.08.11, 09:14
Hello Misa
Very oftenly, Toshiba drives have problems with bearing. Please check if your drive make any strange noises when it is working. I had a case some time ago, when a Toshiba drive was working well, after you put it upside down or on its sides.
You may also measure the resistance on spindle motor coils on a good drive and compare the values with a bad one. Spindle motor problem is also possible.
Waiting for your reply.
misa
Postby misa » 31.08.11, 16:56
I think it's not bearing problem, but I'll try later if no result soon.
Now I can read some sector.
I must start Toshiba Utility for that ("Other SATA")
I can read in all mode (UDMA33, 66 and HW retries) but with many many bad bloc (reading with CRC error) on full surface.
When I restart copy I can read more good sector (green status change)
For exemple I need 10 pass for have 256 good sector and reading slowly ...
I try with reading retries but need restart scan for good result.
I try with different timeout and delay but always the same result.
Any Idea
Regards,
Misa
dmarques
Postby dmarques » 01.09.11, 10:15
That's a common issue with some Toshiba drives.
Try to remove soft reset and work with just hard reset to see if it makes any difference.
misa
Postby misa » 05.09.11, 10:34
Hello and thanks for your help,
I tried to remove soft reset and work just with hard reset but it's worse.
Any idea ?
dmarques
Postby dmarques » 05.09.11, 16:47
Have you increase reading timeout and removed UDMA timeout, so the drive will go to PIO mode?
Postby AJ2008 » 07.09.11, 13:11
Clear map of Dark Green sectors and Increase read retries before a second pass.
Also, clear GLIST can help sometimes.
misa
Postby misa » 13.09.11, 15:46
Thanks for your help !
I already try to increase timeout (and many other parameters) and clear Glist but never good result.
I realised map from alterate MFT and I can read some important file with many retries !
Misa
Return to “Toshiba native”
