I have WD3200AVBS-63TAA0 the pcb no is 2061-701444-000
the PCB was burnt
I have the same PCB nimber 2061-701444 but my question is :
What is the Family of this drive?
Any on have Rom for xxTAxx family?
WD3200AVBS-63TAA0 PCB problem
Re: WD3200AVBS-63TAA0 PCB problem
move the ROM from defected hdd pcb to working pcb and good luck
This model have no rom chip
the rom in the CPU chip and it was burnt
sorry for the mistake ur right here i did not notice
BUT
my best guess is Caviar
can u post the image of pcb other side
just to make sure
BUT
just to make sure
Thank you for the help
my best guess for this is the Spider here since this pcb can be used for many families
another suggestion if you have a backup resources for it, open module C5
you will find the family there
good luck
good luck
Dear einstein9
Thank you for help but unfortunately i don't have any resource for the drive
If you use safe mode, you can see family.
Thank you datalabace
but the PCB was burnt so i can not run kernel mode
Why do you want to know it's family?
I want to write Rom from the same family to get access to SA and recover the Rom of HDD
The i can get the data
hassan, u dont need to know or select family to write the rom
pick any, and write
this will not effect anything since ur writing rom
good luck
pick any, and write
good luck
