Hitachi HTS541616J9SA00 unlocking
pad-dataservice
Postby pad-dataservice » 12.01.11, 00:48
Hi We have a problem with a security locked HTS541616J9SA00 - or at least it states that it's locked.
So far hotswaps and trying to access SA with doner NV-Ram has been unsuccesfull - and the unlocking procedure (below) though stating no errors, gives no result.
Any thoughts on this?
regards
Michael
Code: Select all
Selected family......................... : HTS5416J9
Model by ID............................. : Hitachi HTS541616J9SA00
Password unlocking
Disconnecting PCB
Switching HDD power supply ON
NV-RAM reading.......................... : Ok
NV-RAM data correction................................................ : Ok
NV-RAM writing........................................................ : Ok
FW start flag correction.............................................. : Ok
Connecting PCB
Error reading modules table:
Drive not ready
Module ICES is not found!
HDD Readiness timeout (15000 ms)
Model by ID............................. : <ID IS NOT READ>
dmarques
Re: Hitachi HTS541616J9SA00 unlocking
Postby dmarques » 12.01.11, 10:56
Are you using a donor nv-ram for that???
pad-dataservice
Postby pad-dataservice » 12.01.11, 14:44
No it's the original
dmarques
Postby dmarques » 12.01.11, 16:19
I never had much problems unlocking those.
pad-dataservice
Postby pad-dataservice » 15.01.11, 01:36
Client stated that there was an ATA password - but the one he provided didn't solve the problem.
My best guess is that the module ICES containing the password is damaged.. and that the PC3000 unlocing procedure doesn't verify writing to it.
One could hope for a good copy 1 of the SA - but how do I access that - or know if its reading from it - when the lock's still in place?
