Hi to all!
Four heads, is one bad (0-good, 1-good, 2-good, 3-BAD)
How do I get the most files without changing the heads?
Thanks!
WD3200BEKT
Re: WD3200BEKT
Does HDD calibrate and show ID but H3 is inaccessible, or does spindle stop and no ID is possible?
In both situations there is possibility for access to surfaces 0,1,2 but further info on the symptoms will help
Re: WD3200BEKT
AJ2008 wrote:Does HDD calibrate and show ID but H3 is inaccessible, or does spindle stop and no ID is possible?
Yes, ready id hdd.
Started clone in DE UDMA (head 3 disable)
nothing is impossible!
Re: WD3200BEKT
sempre wrote:Hi to all!
Thanks!
it is easy . in DE . building map menu and then disable head 3
good luck
