MHY2160BH
sg210
MHY2160BH
Postby sg210 » 18.08.10, 11:32
Hi all,
I tried to remove a Password from a MHY2160BH, using Terminal adapter MHV. However, the procedure failed for unknown reason.
Now, the hdd does not give any response at all, any more. (Not even a BSY-Signal when switching on power.)
I examined the PCB, but I did not see any hint for a damage.
Any help, any suggestions?
ddr
Re: MHY2160BH
Postby ddr » 01.09.10, 13:41
Check the fuse, connecting the adapter around the wrong way shorts 5V to ground and blows the protective fuse
Joel
Return to “Fujitsu”
