Work with SAS HDD in PC-3000 for SCSI
Moderator: Sergey_TS
avenger-fr
Postby avenger-fr » 26.03.10, 10:11
PC-3000 SCSI and SAS : list of tested controllers (with universal utility)
Tested OK
- Adaptec ASC-1405 PCI-Express (From AceLab site)
- Adaptec ASC-1045 PCI-Express (From AceLab site)
- P6T WS pro Motherboard internal card chipset Marvell 64xx/63xx SAS controller
Tested NOT COMPATIBLE
- Card HP 8INT Port SAS (PCI-X) with a chipset LSI LOGIC 6208A2 LSISAS1068
avenger-fr
Re: Work with SAS HDD in PC-3000 for SCSI
Postby avenger-fr » 26.03.10, 10:14
Why can we use data extractor with this type of drive (SAS) ?
why only make clone ??? Is it so different from SCSI ???
ZeBong
Postby ZeBong » 30.03.10, 00:42
Is possoble in the PC3K SCSI Tools acess the SAS Service Area ?
Or just clone it as a normal disk with DE ?
-BR-
Postby -BR- » 08.09.10, 09:00
Late answer, but yes!
The kit PC3K SCSI + adaptec 1405 card is able to access SAS fw
It can read modules, tracks, rom, perform head tests, head maping, translator regen, all the good stuff :P
-BR-
ZeBong
Postby ZeBong » 08.09.10, 12:19
Thanks -BR-, for the reply.
I think this should be respond by the support of the pc3kscsi.
I was interesting in buy one.
Jose
mandr
Postby mandr » 08.09.10, 16:06
Except regenerate translator on SAS cheetah :(
Postby ACE_Admin » 09.09.10, 10:43
I confirm , that only Adaptec SAS-adapters mentioned above (Adaptec ASC-1405 and Adaptec ASC-1045 for PCI Express bus) are compartible with PC-3000 SCSI equipment. Unfortunately, other SAS controllers were not tested.
Please specify the model you were not able to recalculate translator.
-BR-
Postby -BR- » 10.09.10, 01:22
Well, I was not able to test all Seagate SAS families yet, but all the ones which I came across, the utility was able to regenerate it's translator succesfully :P
Some recent examples of SAS succesfully regenerated translators:
Model: ST373455SS - Cheetah 15.5K family
Result: translator regeneration was performed succesfully
Model: ST3400755SS - Cheetah NS family
Follows attached a screenshot from Cheetah 15.5K command result
-BR-
Screenshot from SAS Cheetah 15.5K translator regeneration command resulting in success
SAS Cheetah 15.5 translator regeneration.jpg (62.55 KiB) Viewed 29526 times
Postby ACE_Admin » 22.04.11, 14:39
If there were a problem with regenerating translator, please provide hard drive firmware version. I suppose the problem is related to different versions.
