WD5000AAVS-00ZTB0
ZeBong
WD5000AAVS-00ZTB0
Postby ZeBong » 05.11.08, 00:46
Can anyone tell-me which family can i use to this disk : WD5000AAVS-00ZTB0
I have two disk off this model for datarecovery.
First One it detect all ID serial Model.
Second one dont detect anything. ( FOTO2 )
It gives DRD DSC, think PCB.
ZeBong
Igor
Re: WD5000AAVS-00ZTB0
Postby Igor » 05.11.08, 13:44
Hello ZeBong,
This drive WD5000AAVS-00ZTB0 correspond to Spider family, but we do not support it. That is why you couldn't work with it.
Regards.
ZeBong
Postby ZeBong » 05.11.08, 13:59
Hello Igor,
Do you know when it will be supported ?
when i connect the the pc3kumda family pinnacle it gives this :
Techno mode key
RAM:
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected: "VSCE PERM OVL NOT LOADED"
SA SPT.................................. : SA SPT determination error Techno CMD sending error Device Error Detected: "SERVO ERROR CODE BASE SvirCalRRO Hd1"
Head number reading..................... : Ok
ROM:
ROM version............................. : 5C.3BG
ROM generation.......................... : 5C.3BG
Link table version...................... : 01.42.
Head map................................ : 0,1,2,3
Firmware version........................ : 005C003B
Service area:
SA dir reading.......................... : Unknown error. Code(0)
SA Copies avalabled..................... : NONE
ZeBong
Postby AJ2008 » 13.03.09, 14:54
When will support for families such as Spider and Kermit be added?
MrHopper
Postby MrHopper » 06.11.09, 13:56
Hi ZeBong.
I have here the same model and PC3000 gives me the same information. Did you manage the problem with the WD5000AAVS? My PC3000 support spider-models, but I can't find a way to fix the problems.
Best
MrHopper
