MHS2060AT
Bruno
MHS2060AT
Postby Bruno » 26.09.07, 10:36
Hi all
I have a good Fujitsu MHS2060AT Dirve.
It works fine. (only one sector defect)
My idee are, to save the firmware in DB, for later use.
After start the PC-3000UDMA Fujitsu-Utility, i selected the MHS2060AT and Utility start.
Now a Window appears with name "searching for module Table".
In the Log i can read: DB contains no information about this FW
How i can find identify the module table?
thanks for your help
Bruno
Postby ACE_Admin » 27.09.07, 16:14
Dear Bruno
Connect your drive and go to Fujitsu utility. Then wait until the drive goes ready and go to "Tools" menu. Choose "General" and press the "Fujitsu 2.5''\3.5'' " button. Then press "OK" in the next window.
after that, the error message should dissapear.
Bruno
Postby Bruno » 02.10.07, 17:07
Dear Roustam
Thank you for the help ist works fine.
Bruno
Return to “Fujitsu”
