LENSE30256MSP34MEAT3TA
Posted: 29.03.22, 18:49
by headcrash
I have 2 cases of LENSE30xxxMSP34MEAT3TA, where the firmware fix works with no errors, translator builds successfully but when imaging in DE, 99% of the sectors are read as "missed marker".
What does this mean?
Is this recoverable or fixable?
Thanks!
Re: LENSE30256MSP34MEAT3TA
Posted: 30.03.22, 09:27
by Roman_TS
Hello. You need to activate the Decryption of the data. Current NVMe drives based on 88SS1093 are using a TCG OPAL Encryption.
Exit from DE, return back to Marvell Utility and follow by: Tests -> Service Information -> TCG -> Load Configuration.
After that, make a new task in DE (chose PC-3000 Utility as a source) and data would be available. Step-by-step guide is right here:
https://youtu.be/47eXzxZk-0E?t=7191
Posted: 04.04.22, 18:11
by headcrash
Thank you for the information, it worked one one of the two drives.
Posted: 05.04.22, 09:43
by Roman_TS
You can contact TS dpt and our engineers will help you with the second drive. Solution for 88SS1093 is pretty flexible and should work almost with all models of Lenovo/Ramaxel.
