HDT721010SLA360 after PCB replacement
Posted: 20.11.13, 04:45
I have a HDT721010SLA360.
Original PCB dead, disk not spinning, no indicator in utility.
Replaced PCB, transferred NV-RAM and ROM. Drive spins up and DRD/DSC. ID on utility start fails with UNC/INF/AMN. I select the family HDx7210SL and start utility, here is the log
<begin>
Selected family......................... : HDx7210SL
Model by ID............................. :
NV-RAM reading.......................... : Ok
Module not read (USAG)
Error : Device error detected (INF)
Error :............................................................... : Module not read (USAG)
Error :............................................................... : Error executing loading "open" modules dir command
Module ZONE is not found!
Module is not loaded (USAG, Main module table)
<end>
I tried:
NV-RAM adjustment (SA search) - each read attempt fails with INF
Editing NV-RAM and changing heads to 5 from 6 - no difference except that drive stays busy after a read attempt
Check modules - report is here
<begin>
ROM ID.................................. : A30A
NV-RAM ID............................... : ST6NA31Â
USAG version............................ : <ERROR!>
NV-RAM parameters
NV-RAM report
Loaded.................................. : No
Used module table
Report on module USAG, "Main module table"
ABA..................................... : FE020000
Length (sectors)........................ : 2
ID : Copy : Importn.: ABA : ABA : Size : Read : Size : Address in : Read : Hdr : Description
original): (sect): (sect): (byte) : RAM : : :
RSVD : 0 : B : FD020000 : FD020000 : 4 : 0 : 2048 : 00000000 : No : : SA marker
RSVD : 1 : B : FD021000 : FD020000 : 4 : 0 : 2048 : 00000000 : No : : SA marker
RSVD : F : B : FD060000 : FD020000 : 4 : 0 : 2048 : 00000000 : No : : SA marker
USAG : 0 : B : FE020000 : FE020000 : 2 : 0 : 1024 : 00000000 : No : : Main module table
USAG : 1 : B : FE021000 : FE020000 : 2 : 0 : 1024 : 00000000 : No : : Main module table
USAG : F : B : FE060000 : FE020000 : 2 : 0 : 1024 : 00000000 : No : : Main module table
PESD : : D : FE090000 : FE090000 : 128 : 0 : 65536 : 00000000 : No : : PES data log
SRST : : C : FE0B0000 : FE0B0000 : 255 : 0 : 130560 : 00000000 : No : : Self Test report module
SSSC : : Dr : FE0A0009 : FE0A0009 : 5 : 0 : 2560 : 00000000 : No : : Self Test management and status module
SSCD : : Dr : FE0A0018 : FE0A0018 : 81 : 0 : 41472 : 00000000 : No : : Self Test code module
NVRC : : Dd : FE0602FC : FE0602FC : 4 : 0 : 2048 : 00000000 : No : : NV-RAM image module
Modules checking completed
Information about copy 0
Module not loaded! ID = RSVD Copy 0; SA marker
Error : Module is not loaded (RSVD, SA marker)
Module not loaded! ID = USAG Copy 0; Main module table
Error : Module is not loaded (USAG, Main module table)
Information about copy 1
Module not loaded! ID = RSVD Copy 1; SA marker
Module not loaded! ID = USAG Copy 1; Main module table
Information about factory copy
Module not loaded! ID = RSVD Copy F; SA marker
Module not loaded! ID = USAG Copy F; Main module table
Information about common modules (Open+Spec)
Module not loaded! ID = SSSC; Self Test management and status module
Error : Module is not loaded (SSSC, Self Test management and status module)
<end>
Obviously, can't read any modules.
What can I do next? Is there a way to check integrity of NV-RAM data (CS OK when I tried NV-RAM edit)? Is it possible that pre-amp is faulty although drive gets DRD/DSC?
Any idea and suggestion much appreciated.
<begin>
<end>
I tried:
<begin>
NV-RAM parameters
NV-RAM report
Used module table
<end>
