head swap on HDP725050GLA360 P/N 0A37728
Posted: 14.10.13, 17:43
by hddr49
Hi there,
I'm looking for donnor drive.
This P/N is very diffucult to obtain, so I try to obtain information on users that have successfully swap heads with differents P/N
(original topic here for this drive :
viewtopic.php?f=2&t=7842)
Thanks for help !
Re: head swap on HDP725050GLA360 P/N 0A37728
Posted: 26.11.13, 13:58
by dmarques
I think it's better for you to get a donor than to do hotswap on those.
Posted: 27.11.13, 12:38
by hddr49
yes, but I don't find any donnor for this one.
search for it since 6 month...
Posted: 27.11.13, 15:29
by dmarques
Why don't you forget about P/N and just buy the same model?
Posted: 27.11.13, 15:50
datalabace wrote:Why don't you forget about P/N and just buy the same model?
Totally agree. PN may be preferable, but in my experience it does not always need to be perfectly matched, in some successful cases there is even no match to PN...
Posted: 27.11.13, 17:17
by hddr49
unfortunally already bought 2 of same model
heads don't match. Unlucky guy ?
donnor heads are ok, I back them into donnor drive
patient heads don't work in donnor drive
I search same P/N or same MLC ... what else ?
Posted: 27.11.13, 17:59
by dmarques
What do you mean they don't work, they knock?
Posted: 29.11.13, 11:29
by hddr49
yes, they knock.
Posted: 29.11.13, 12:09
by dmarques
Do you have microscope to check head pattern?
Posted: 02.12.13, 14:31
by hddr49
no, I don't.
But I can buy one if relevant.
Posted: 03.12.13, 10:00
by dmarques
I think it's a must have tool in your LAB!
Posted: 04.12.13, 08:59
by hddr49
ok then.
where should I look on the heads to see head pattern ?
compare with other good heads ?
Posted: 05.12.13, 12:19
by dmarques
You should compare it with your donors.
Posted: 06.12.13, 09:24
by hddr49
thanks for your helps.
I will do this.
We learn every day in data recovery...
