Hello ,
HDD 7K750-750(HTS727575A9E364)
Type Ts7SAD750 P/N H2T7501672S
750 GB Hitachi HDD goes DRD/DSC(ready) state but if i go to DE give error "error while reading drive's ID"
if i try to read ID in universal Utility Device error detected "ABR"
Also Following error at universal utility starts
1.HDD does not support set max LBA
2.?????????????????? SMART
No clicking Sound , Motor Spins, No spin down .
Please help
Hitachi 750 GB
Re: Hitachi 750 GB
Hello alphapune.
Check modules, analyze damaged and try to recovery it.
Re: Hitachi 750 GB
Did you try to access under the appropriate utility? You need to get access to its service area if possible, this cant be done under universal utility or direct in DE
Re: Hitachi 750 GB
Sir i gone through following utility
Selected family......................... : 7275A9
Model by ID............................. :
ROM VER................................. : 0Y1
NV-RAM ID............................... : 2004JF4HD0Z3
NV-RAM parameters
NV-RAM report
ID...................................... : E2PR
mu-code................................. : 2004JF4HD0Z3
Heads................................... : 4
Head map................................ : 0 1 2 3 F F F F F F
Used module table
Report on module USAG, "Main module table"
ABA..................................... : 3F0000004
Length (sectors)........................ : 4
Loaded.................................. : No
ID : Copy : Importn.: ABA : ABA : Size : Read : Size : Address in : Read : Hdr : Description
: : : : (original) : (sect): (sect): (byte) : RAM : : :
RPSH : 0 : B : 3F0000000 : 3F0000000 : 4 : 0 : 2048 : 00000000 : No : : SA marker
RPSH : 1 : B : 3F0100000 : 3F0000000 : 4 : 0 : 2048 : 00000000 : No : : SA marker
USAG : 0 : B : 3F0000004 : 3F0000004 : 4 : 0 : 2048 : 00000000 : No : : Main module table
USAG : 1 : B : 3F0100004 : 3F0000004 : 4 : 0 : 2048 : 00000000 : No : : Main module table
MFGP : 0 : Dr : 3F0003E00 : 3F0003E00 : 1 : 0 : 512 : 00000000 : No : : Self Test parameters module
MFGP : 1 : Dr : 3F0103E00 : 3F0003E00 : 1 : 0 : 512 : 00000000 : No : : Self Test parameters module
Modules checking completed
NV-RAM parameters
NV-RAM report
Used module table
Re: Hitachi 750 GB
Module table does not load. After you enter utility what appears on the log?
Re: Hitachi 750 GB
Following LOG
Error startintg command: Reading SA [0x3F0000004, 0x4]
Device error detected (ABR)
Error startintg command: Reading SA [0x3F0000004, 0x1]
Error reading module USAG(0): Error startintg command: Reading SA [0x3F0000004, 0x1]
Error startintg command: Reading SA [0x3F0100004, 0x4]
Error startintg command: Reading SA [0x3F0100004, 0x1]
Error reading module USAG(1): Error startintg command: Reading SA [0x3F0100004, 0x1]
Error :............................................................... : Module USAG: no copies read!
Error :............................................................... : Error executing loading "open" modules dir command
Re: Hitachi 750 GB
alphapune wrote:Loading modules table................................................. : Error
You do not have access to SA. Probably there is some hardware problem or PCB is not native. Set to 'PCB only' and view SN in NVRAM. If it is native, then you should look into possibility that there is some hardware error and try replacement PCB.
Do you hear head seeking after power on?
Re: Hitachi 750 GB
PCB is native.
Do you mean head seeking means initializing? yes it is intializing
