HDS721010KLA330 - problem after change PCB
Posted: 11.08.11, 11:47
by igen
I have big (maybe smal) problem...
I have 2 disk HDS721010KLA330 and HUA721010KLA330.
The second (HUA...) i have save full SA in my base. The first unfortunately no have ...
By mistake i was changed PCB from one to other and inversely.
After this mistake i corect place of PCB and...both hdd not detected.
After revrite nvram for HUA721010KLA330 (from SA base) the disk began detected corect.
Unfortunately, i dont have the second HDD copy SAfor HDS721010KLA330.
I run the utility by custom family (as 7210KLA3, HDS7210xxKLxxx0) and below is result of SA structure checking:
Selected family......................... : CUSTOM
Model by ID............................. :
ROM ID.................................. : 9āD
NV-RAM ID............................... : GKANR70M
USAG version............................ : GKANR70M
NV-RAM parameters
NV-RAM report
Loaded.................................. : Yes
Checksum................................ : Ok
ID...................................... : E2PR
mu-code................................. : GKANR70M
FW Ver Code............................. : 0xCCF5F589
Heads................................... : 10
Head map................................ : 7 6 5 4 2 1 0 3 89 2E
Module copy ABA modifier for SA......... : 0x1000
Base for cyl defect list................ : 0x640
SA top cyl delimiter.................... : 0x17232
Used module table
Report on module USAG, "Main module table"
ABA..................................... : 7FE20000
Length (sectors)........................ : 2
Identified.............................. : Yes
FW Ver code............................. : CCF5F589
ID : Copy : Importn.: ABA : ABA : Size : Read : Size : Address in : Read : Hdr : Description
: : : :(original): (sect): (sect): (byte) : RAM : : :
RSVD : 0 : B : 7FD20000 : 7FD20000 : 4 : 4 : 2048 : 00000000 : Yes : Ok : SA marker
RSVD : 1 : B : 7FD21000 : 7FD20000 : 4 : 4 : 2048 : 00000000 : Yes : Ok : SA marker
RSVD : F : B : 7FD60000 : 7FD20000 : 4 : 0 : 2048 : 00000000 : No : : SA marker
USAG : 0 : B : 7FE20000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
USAG : 1 : B : 7FE21000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
USAG : F : B : 7FE60000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
PSHT : 0 : Ad : 7FE40000 : 7FE40000 : 256 : 256 : 0 : 00000A00 : Yes : Ok : P-List module
PSHT : 1 : Ad : 7FE41000 : 7FE40000 : 256 : 256 : 0 : 00000A00 : Yes : Ok : P-List module
PSHT : F : Ad : 7FE61000 : 7FE40000 : 256 : 256 : 0 : 00000A00 : Yes : Ok : P-List module
RDMT : 0 : Ad : 7FE40100 : 7FE40100 : 32 : 32 : 16384 : 00020A00 : Yes : Ok : G-List module
RDMT : 1 : Ad : 7FE41100 : 7FE40100 : 32 : 32 : 16384 : 00020A00 : Yes : Ok : G-List module
RDMT : F : Ad : 7FE61100 : 7FE40100 : 32 : 32 : 16384 : 00020A00 : Yes : Ok : G-List module
RLBA : 0 : B : 7FE20115 : 7FE20115 : 1 : 1 : 80 : 0002CF80 : Yes : Ok : G-List reserves table module
RLBA : 1 : B : 7FE21115 : 7FE20115 : 1 : 1 : 80 : 0002CF80 : Yes : Ok : G-List reserves table module
RLBA : F : B : 7FE60115 : 7FE20115 : 1 : 1 : 80 : 0002CF80 : Yes : Ok : G-List reserves table module
CNSL : 0 : B : 7FE200FB : 7FE200FB : 1 : 1 : 480 : 0003CA00 : Yes : Ok : HDD logical configuration module
CNSL : 1 : B : 7FE210FB : 7FE200FB : 1 : 1 : 480 : 0003CA00 : Yes : Ok : HDD logical configuration module
CNSL : F : B : 7FE600FB : 7FE200FB : 1 : 1 : 480 : 0003CA00 : Yes : Ok : HDD logical configuration module
RWCN : 0 : B : 7FE200FC : 7FE200FC : 1 : 1 : 120 : 0003D28E : Yes : Ok :
RWCN : 1 : B : 7FE210FC : 7FE200FC : 1 : 1 : 120 : 0003D28E : Yes : Ok :
RWCN : F : B : 7FE600FC : 7FE200FC : 1 : 1 : 120 : 0003D28E : Yes : Ok :
CHNM : 0 : Ad : 7FE2012E : 7FE2012E : 55 : 55 : 27756 : 00032200 : Yes : Ok :
CHNM : 1 : Ad : 7FE2112E : 7FE2012E : 55 : 55 : 27756 : 00032200 : Yes : Ok :
CHNM : F : Ad : 7FE6012E : 7FE2012E : 55 : 55 : 27756 : 00032200 : Yes : Ok :
SRVP : 0 : B : 7FE200FF : 7FE200FF : 2 : 2 : 662 : 00039000 : Yes : Ok :
SRVP : 1 : B : 7FE210FF : 7FE200FF : 2 : 2 : 662 : 00039000 : Yes : Ok :
SRVP : F : B : 7FE600FF : 7FE200FF : 2 : 2 : 662 : 00039000 : Yes : Ok :
SRVM : 0 : Ad : 7FE20116 : 7FE20116 : 16 : 16 : 7716 : 00039400 : Yes : Ok : Module contains cylinder defects table
SRVM : 1 : Ad : 7FE21116 : 7FE20116 : 16 : 16 : 7716 : 00039400 : Yes : Ok : Module contains cylinder defects table
SRVM : F : Ad : 7FE60116 : 7FE20116 : 16 : 16 : 7716 : 00039400 : Yes : Ok : Module contains cylinder defects table
ALTC : 0 : : 7FE20126 : 7FE20126 : 8 : 8 : 3088 : 0002F300 : Yes : Ok :
ALTC : 1 : : 7FE21126 : 7FE20126 : 8 : 8 : 3088 : 0002F300 : Yes : Ok :
ALTC : F : : 7FE60126 : 7FE20126 : 8 : 8 : 3088 : 0002F300 : Yes : Ok :
ZONE : 0 : Ad : 7FE2010D : 7FE2010D : 3 : 3 : 1425 : 0003C400 : Yes : Ok : Zone allocation table module
ZONE : 1 : Ad : 7FE2110D : 7FE2010D : 3 : 3 : 1425 : 0003C400 : Yes : Ok : Zone allocation table module
ZONE : F : Ad : 7FE6010D : 7FE2010D : 3 : 3 : 1425 : 0003C400 : Yes : Ok : Zone allocation table module
PTRT : 0 : B : 7FE20114 : 7FE20114 : 1 : 1 : 480 : 0002AEB0 : Yes : Ok :
PTRT : 1 : B : 7FE21114 : 7FE20114 : 1 : 1 : 480 : 0002AEB0 : Yes : Ok :
PTRT : F : B : 7FE60114 : 7FE20114 : 1 : 1 : 480 : 0002AEB0 : Yes : Ok :
RAM0 : 0 : B : 7FE20002 : 7FE20002 : 125 : 125 : 64000 : 00050000 : Yes : Ok : Code module
RAM0 : 1 : B : 7FE21002 : 7FE20002 : 125 : 125 : 64000 : 00050000 : Yes : Ok : Code module
RAM0 : F : B : 7FE60002 : 7FE20002 : 125 : 125 : 64000 : 00050000 : Yes : Ok : Code module
OVR1 : 0 : B : 7FE2007F : 7FE2007F : 120 : 120 : 12288 : 0005FA00 : Yes : Ok : Code overlay module
OVR1 : 1 : B : 7FE2107F : 7FE2007F : 120 : 120 : 12288 : 0005FA00 : Yes : Ok : Code overlay module
OVR1 : F : B : 7FE6007F : 7FE2007F : 120 : 120 : 12288 : 0005FA00 : Yes : Ok : Code overlay module
SMRT : 0 : B : 7FE20104 : 7FE20104 : 1 : 1 : 512 : 0003C200 : Yes : Ok : S.M.A.R.T. module
SMRT : 1 : B : 7FE21104 : 7FE20104 : 1 : 1 : 512 : 0003C200 : Yes : Ok : S.M.A.R.T. module
SMRT : F : B : 7FE60104 : 7FE20104 : 1 : 1 : 512 : 0003C200 : Yes : Ok : S.M.A.R.T. module
MLBA : 0 : B : 7FE20105 : 7FE20105 : 1 : 1 : 302 : 0003CC00 : Yes : Ok : HDD logical configuration module
MLBA : 1 : B : 7FE21105 : 7FE20105 : 1 : 1 : 302 : 0003CC00 : Yes : Ok : HDD logical configuration module
MLBA : F : B : 7FE60105 : 7FE20105 : 1 : 1 : 302 : 0003CC00 : Yes : Ok : HDD logical configuration module
SECI : 0 : B : 7FE20106 : 7FE20106 : 1 : 1 : 74 : 0002CF30 : Yes : Ok : Security information module
SECI : 1 : B : 7FE21106 : 7FE20106 : 1 : 1 : 74 : 0002CF30 : Yes : Ok : Security information module
SECI : F : B : 7FE60106 : 7FE20106 : 1 : 1 : 74 : 0002CF30 : Yes : Ok : Security information module
SRIF : 0 : B : 7FE20101 : 7FE20101 : 1 : 1 : 2 : 0003D6A4 : Yes : Ok : Self Test start management module
SRIF : 1 : B : 7FE21101 : 7FE20101 : 1 : 1 : 2 : 0003D6A4 : Yes : Ok : Self Test start management module
SRIF : F : B : 7FE60101 : 7FE20101 : 1 : 1 : 2 : 0003D6A4 : Yes : Ok : Self Test start management module
SERL : 0 : B : 7FE20108 : 7FE20108 : 3 : 3 : 1536 : 00031800 : Yes : Ok : S.M.A.R.T. error log module
SERL : 1 : B : 7FE21108 : 7FE20108 : 3 : 3 : 1536 : 00031800 : Yes : Ok : S.M.A.R.T. error log module
SERL : F : B : 7FE60108 : 7FE20108 : 3 : 3 : 1536 : 00031800 : Yes : Ok : S.M.A.R.T. error log module
IDNT : 0 : B : 7FE200FD : 7FE200FD : 2 : 2 : 560 : 0002B0D0 : Yes : Ok : HDD ID data module
IDNT : 1 : B : 7FE210FD : 7FE200FD : 2 : 2 : 560 : 0002B0D0 : Yes : Ok : HDD ID data module
IDNT : F : B : 7FE600FD : 7FE200FD : 2 : 2 : 560 : 0002B0D0 : Yes : Ok : HDD ID data module
DCOT : 0 : B : 7FE20107 : 7FE20107 : 1 : 1 : 14 : 00030000 : Yes : Ok :
DCOT : 1 : B : 7FE21107 : 7FE20107 : 1 : 1 : 14 : 00030000 : Yes : Ok :
DCOT : F : B : 7FE60107 : 7FE20107 : 1 : 1 : 14 : 00030000 : Yes : Ok :
PTCH : 0 : B : 7FE200F7 : 7FE200F7 : 3 : 3 : 1305 : 00062A00 : Yes : Ok : Microcode connections table module
PTCH : 1 : B : 7FE210F7 : 7FE200F7 : 3 : 3 : 1305 : 00062A00 : Yes : Ok : Microcode connections table module
PTCH : F : B : 7FE600F7 : 7FE200F7 : 3 : 3 : 1305 : 00062A00 : Yes : Ok : Microcode connections table module
##01 : 0 : : 7FE200FA : 7FE200FA : 1 : 1 : 512 : 00000002 : Yes : Skip : Main SA track hole
##01 : 1 : : 7FE210FA : 7FE200FA : 1 : 1 : 512 : 00000002 : Yes : Skip : Main SA track hole
##01 : F : : 7FE600FA : 7FE200FA : 1 : 1 : 512 : 00000002 : Yes : Skip : Main SA track hole
##02 : 0 : : 7FE20102 : 7FE20102 : 2 : 2 : 1024 : 00000002 : Yes : Skip : Main SA track hole
##02 : 1 : : 7FE21102 : 7FE20102 : 2 : 2 : 1024 : 00000002 : Yes : Skip : Main SA track hole
##02 : F : : 7FE60102 : 7FE20102 : 2 : 2 : 1024 : 00000002 : Yes : Skip : Main SA track hole
##03 : 0 : : 7FE2010B : 7FE2010B : 2 : 2 : 1024 : 00000002 : Yes : Skip : Main SA track hole
##03 : 1 : : 7FE2110B : 7FE2010B : 2 : 2 : 1024 : 00000002 : Yes : Skip : Main SA track hole
##03 : F : : 7FE6010B : 7FE2010B : 2 : 2 : 1024 : 00000002 : Yes : Skip : Main SA track hole
##04 : 0 : : 7FE20110 : 7FE20110 : 4 : 4 : 2048 : 00000002 : Yes : Skip : Main SA track hole
##04 : 1 : : 7FE21110 : 7FE20110 : 4 : 4 : 2048 : 00000002 : Yes : Skip : Main SA track hole
##04 : F : : 7FE60110 : 7FE20110 : 4 : 4 : 2048 : 00000002 : Yes : Skip : Main SA track hole
PESD : : D : 7FE90000 : 7FE90000 : 128 : 128 : 65536 : 00000000 : Yes : Error : PES data log
SRST : : C : 7FEB0000 : 7FEB0000 : 255 : 255 : 130560 : 00000000 : Yes : Skip : Self Test report module
SSSC : : Dr : 7FEA0009 : 7FEA0009 : 5 : 5 : 2560 : 00000000 : Yes : Skip : Self Test management and status module
SSCD : : Dr : 7FEA0018 : 7FEA0018 : 49 : 49 : 25088 : 00000000 : Yes : Skip : Self Test code module
NVRC : : Dd : 7FEA01FE : 7FEA01FE : 2 : 2 : 1024 : 00000000 : Yes : Ok : NV-RAM image module
Modules checking completed
Information about copy 0
Report on module RSVD, "SA marker"
ABA..................................... : 7FD20000
Length (sectors)........................ : 4
Report on module RAM0, "Code module"
ABA..................................... : 7FE20002
Length (sectors)........................ : 125
mu-code................................. : A70M
Incompatible with active USAG!
Report on module OVR1, "Code overlay module"
ABA..................................... : 7FE2007F
Length (sectors)........................ : 120
Report on module IDNT, "HDD ID data module"
ABA..................................... : 7FE200FD
Firmware................................ : GKAOA70M
Model................................... : Hitachi HDS721010KLA320
Serial.................................. : GTA100PAG4NXZA
Report on module CNSL, "HDD logical configuration module"
ABA..................................... : 7FE200FB
AutoReassign............................ : OFF
Maximal LBA............................. : 1953525167
Report on module MLBA, "HDD logical configuration module"
ABA..................................... : 7FE20105
Capacity................................ : 302590082
Maximal LBA............................. : 29449726
Report on module ZONE, "Zone allocation table module"
ABA..................................... : 7FE2010D
Length (sectors)........................ : 3
Zones count............................. : 30
# Init. LBA Init. Cyl End Cyl SPC SPT
0 : 0 : 0 : 10111 : 49152 : 32
1 : 169552976 : 10112 : 18431 : 44032 : 32
2 : 308726576 : 18432 : 23679 : 44032 : 32
3 : 396513440 : 23680 : 31871 : 49152 : 31
4 : 529679328 : 31872 : 34687 : 36864 : 31
5 : 575184268 : 34688 : 40447 : 12288 : 31
6 : 667158348 : 40448 : 47999 : 24576 : 30
7 : 784603932 : 48000 : 54399 : 45056 : 29
8 : 881880892 : 54400 : 59519 : 62464 : 28
9 : 957778284 : 59520 : 65919 : 8192 : 28
10 : 1049935404 : 65920 : 71039 : 8192 : 28
11 : 1123661964 : 71040 : 74111 : 15360 : 27
12 : 1166496540 : 74112 : 78335 : 36864 : 26
13 : 1223941580 : 78336 : 82815 : 51200 : 25
14 : 1283076260 : 82816 : 86015 : 51200 : 25
15 : 1325316260 : 86016 : 90367 : 0 : 25
16 : 1381019300 : 90368 : 94719 : 27648 : 24
17 : 1435435460 : 94720 : 100735 : 28672 : 23
18 : 1507626260 : 100736 : 104575 : 24576 : 23
19 : 1553582180 : 104576 : 110335 : 62464 : 21
20 : 1618323460 : 110336 : 113151 : 57344 : 21
21 : 1649861540 : 113152 : 116351 : 6144 : 21
22 : 1684420460 : 116352 : 119295 : 2048 : 21
23 : 1716120372 : 119296 : 123775 : 15360 : 20
24 : 1762532132 : 123776 : 126335 : 43008 : 19
25 : 1788295972 : 126336 : 131199 : 49152 : 18
26 : 1834988452 : 131200 : 135167 : 38912 : 18
27 : 1872763812 : 135168 : 138367 : 50176 : 17
28 : 1901870100 : 138368 : 141695 : 8192 : 17
29 : 1931049124 : 141696 : -1 : 26624 : 16
Module not loaded! ID = SRVM Copy 0; Module contains cylinder defects table
Error : Invalid Cyl table defects count info!(1)
Report on module RDMT, "G-List module"
ABA..................................... : 7FE40100
Length (sectors)........................ : 32
Header
Capacity................................ : 1900
Defects count........................... : 181
Grown................................... : 111
Data:
Candidate............................... : 81
Total hidden (cand.).................... : 81
Total hidden (grown).................... : 111
Information about copy 1
Module not loaded! ID = SRVM Copy 1; Module contains cylinder defects table
Header
Data:
Information about factory copy
Module not loaded! ID = RSVD Copy F; SA marker
Error : Module is not loaded (RSVD, SA marker)
mu-code................................. : GKAOR70G
FW Ver code............................. : 8DCC0342
Incompatible with NV-RAM!
mu-code................................. : A70G
Firmware................................ : GKAOA70G
AutoReassign............................ : ON
Module not loaded! ID = SRVM Copy F; Module contains cylinder defects table
Header
Defects count........................... : 0
Grown................................... : 0
Data:
Candidate............................... : 0
Total hidden (cand.).................... : 0
Total hidden (grown).................... : 0
Information about common modules (Open+Spec)
Report on module SSSC, "Self Test management and status module"
ABA..................................... : 7FEA0009
Length (sectors)........................ : 5
Result.................................. : COMPFIN1
Error code.............................. : 0000
Below is picture from edit nvram:
edytor nvram.JPG (29.11 KiB) Viewed 8396 times
I tried rewrite nvram by nvram adjustment and .... nothing change - the same situation...
What i can to do it more for detect of disk ...???
Thanks for all answer :)
Re: HDS721010KLA330 - problem after change PCB
Posted: 11.08.11, 15:56
by Igor
Attach here please NVRAM from this disk. In rar or zip file.
Posted: 11.08.11, 17:15
by igen
Hi Igor,
Great thanks for quick reply.....
In att i send for You file nvram.
NV-RAM.zip
(992 Bytes) Downloaded 488 times
Again thanks and wait for your solution
Posted: 16.08.11, 14:06
by Igor
Try to write attached NVRAM to your disk.
NV-RAM.rar
(981 Bytes) Downloaded 1074 times
Posted: 16.08.11, 18:16
by igen
Great thanks IGOR - hdd run corectly !!!
One question yet - what happends ??
Posted: 18.08.11, 09:37
by Igor
You are welcome!
When you change PCBs between two good drives, several bytes in NVRAM can be changed because of incompatibility. These are bytes of error. I turned it back.
Posted: 07.09.11, 13:41
Igor wrote::)
You are welcome!
What bytes are these? Can you tell me offset they are at?
I am curious, I never see before :)
Posted: 07.09.11, 13:47
by Igor
AJ2008 wrote:
Igor wrote::)
You are welcome!
It's different in each family. Maybe later I will make some table.
Look forward to it.
Thank Igor :)
