HDS721616PLA300 show ABR error
Posted: 25.07.10, 13:07
by hassan
I have Hitachi HDS721616PLA300
When i power in start with normal sound and became ready
(some times when i power it knok for 3..10 times then became ready)
but when i start the Hitachi-IBM utility show
DRD , DSC , DRQ , ERR()ABR all on
HDD ID has not been read Error read HDD ID (ABR)
I run the utility and select HDS7216PL family
Loading data for correction of HDD family handling settings from section DPTA
Selected family......................... : HDx7216PL
WARNING! The HDD may be in limited SA access mode at the moment!
Module not read (USAG)
Error : Device error detected (UNC)
Error :............................................................... : Module not read (USAG)
Module ZONE is not found!
Module is not loaded (USAG, Main module table)
Test : Start SA checking
Module checking
Module RSVD Copy 0...................... : Error
Module RSVD Copy 1...................... : Error
Module USAG Copy 0...................... : Error
Module USAG Copy 1...................... : Error
Module USAG Copy F...................... : Error
Module PESD............................. : Error
Module SRST............................. : Error
Module SSSC............................. : Error
Module SSCD............................. : Error
Module NVRC............................. : Ok
Module RAM0 is not found!
Module not created! RAM0
Module OVR1 is not found!
Module not created! OVR1
Module IDNT is not found!
Module not created! IDNT
Module CNSL is not found!
Module not created! CNSL
Module MLBA is not found!
Module not created! MLBA
Module PIDM is not found!
Module not created! PIDM
Module not created! ZONE
Module SRVM is not found!
Module not created! SRVM
Module RDMT is not found!
Module not created! RDMT
Module MFGP is not found!
Module not created! MFGP
So what can i do to get data?
Best Regards.
Re: HDS721616PLA300 show ABR error
Posted: 25.07.10, 20:43
by Issam
based on my experience with such drive, the service area is damaged, replacing heads will not help.
