Problem with Hitachi HTS541010G9SA00 - Please Help me !
Powermax
Postby Powermax » 05.09.08, 11:21
I need to recover data from Hitachi HTS541010G9SA00.
The Hdd go to ready status.
When i run PC3KUDMA Utility, they report me the "HDD ID Has not been read".
Now i select HTS541 utility and start it. Report the follow message :
Loading data for correction of HDD family handling settings from section DPTA
Selected family......................... : HTS541
NV-RAM reading.......................... : Ok
Loading modules table................................................. : Ok
Error :............................................................... : Error executing loading "open" modules dir command
Loading zone allocation table......................................... : Ok
Now i start SA Structure check, Follow the report :
ROM ID.................................. : C60P
NV-RAM ID............................... : C60P
RESF version............................ : C60P
NV-RAM parameters
NV-RAM report
Checksum................................ : Ok
mu-code................................. : C60P
FW Ver Code............................. : 0x9948F63D
Head map................................ : 0 1 2 3
FW boot flag............................ : 0x81
SA top cyl delimiters (by heads)........ : 0x788B; 0x788B; 0x788B; 0x788B
Used module table
Report on module RESF, "Main module table"
ABA..................................... : 7FE20000
Length (sectors)........................ : 2
Identified.............................. : Yes
FW Ver code............................. : 00000000
ID : Copy : Importn.: ABA : ABA : Size : Read : Size : Address in : Read : Hdr : Description
: : : :(original): (sect): (sect): (byte) : RAM : : :
RSVD : 0 : B : 7FD20000 : 7FD20000 : 3 : 3 : 1536 : 00000000 : Yes : Ok : SA marker
RSVD : 1 : B : 7FD21000 : 7FD20000 : 3 : 3 : 1536 : 00000000 : Yes : Ok : SA marker
RSVD : F : B : 7FD00000 : 7FD20000 : 3 : 0 : 1536 : 00000000 : No : : SA marker
RESF : 0 : B : 7FE20000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
RESF : 1 : B : 7FE21000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
RESF : F : B : 7FE00000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
RAM0 : 0 : B : 7FE20002 : 7FE20002 : 138 : 138 : 0 : 0004C800 : Yes : Ok : Code module
RAM0 : 1 : B : 7FE21002 : 7FE20002 : 138 : 138 : 0 : 0004C800 : Yes : Ok : Code module
RAM0 : F : B : 7FE00002 : 7FE20002 : 138 : 138 : 0 : 0004C800 : Yes : Ok : Code module
OVR0 : 0 : B : 7FE2008C : 7FE2008C : 18 : 18 : 0 : 0005DC00 : Yes : Ok : Code overlay module
OVR0 : 1 : B : 7FE2108C : 7FE2008C : 18 : 18 : 0 : 0005DC00 : Yes : Ok : Code overlay module
OVR0 : F : B : 7FE0008C : 7FE2008C : 18 : 18 : 0 : 0005DC00 : Yes : Ok : Code overlay module
RESF : 0 : B : 7FE2009E : 7FE2009E : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
RESF : 1 : B : 7FE2109E : 7FE2009E : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
RESF : F : B : 7FE0009E : 7FE2009E : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
PTCH : 0 : B : 7FE200A0 : 7FE200A0 : 3 : 3 : 0 : 000FFFFF : Yes : Ok : Microcode connections table module
PTCH : 1 : B : 7FE210A0 : 7FE200A0 : 3 : 3 : 0 : 000FFFFF : Yes : Ok : Microcode connections table module
PTCH : F : B : 7FE000A0 : 7FE200A0 : 3 : 3 : 0 : 000FFFFF : Yes : Ok : Microcode connections table module
CNS1 : 0 : B : 7FE200A3 : 7FE200A3 : 1 : 0 : 386 : 00034E80 : No : : HDD logical configuration module
CNS1 : 1 : B : 7FE210A3 : 7FE200A3 : 1 : 1 : 386 : 00034E80 : Yes : Ok : HDD logical configuration module
CNS1 : F : B : 7FE000A3 : 7FE200A3 : 1 : 1 : 386 : 00034E80 : Yes : Ok : HDD logical configuration module
RWCN : 0 : B : 7FE200A4 : 7FE200A4 : 1 : 1 : 96 : 0003AAF0 : Yes : Ok :
RWCN : 1 : B : 7FE210A4 : 7FE200A4 : 1 : 1 : 96 : 0003AAF0 : Yes : Ok :
RWCN : F : B : 7FE000A4 : 7FE200A4 : 1 : 1 : 96 : 0003AAF0 : Yes : Ok :
ZONE : 0 : Ad : 7FE200A5 : 7FE200A5 : 10 : 10 : 4612 : 00038C00 : Yes : Ok : Zone allocation table module
ZONE : 1 : Ad : 7FE210A5 : 7FE200A5 : 10 : 10 : 4612 : 00038C00 : Yes : Ok : Zone allocation table module
ZONE : F : Ad : 7FE000A5 : 7FE200A5 : 10 : 10 : 4612 : 00038C00 : Yes : Ok : Zone allocation table module
PTRT : 0 : B : 7FE200AF : 7FE200AF : 2 : 2 : 640 : 000E8580 : Yes : Ok :
PTRT : 1 : B : 7FE210AF : 7FE200AF : 2 : 2 : 640 : 000E8580 : Yes : Ok :
PTRT : F : B : 7FE000AF : 7FE200AF : 2 : 2 : 640 : 000E8580 : Yes : Ok :
SRVP : 0 : B : 7FE200B1 : 7FE200B1 : 1 : 1 : 272 : 0003C72C : Yes : Ok :
SRVP : 1 : B : 7FE210B1 : 7FE200B1 : 1 : 1 : 272 : 0003C72C : Yes : Ok :
SRVP : F : B : 7FE000B1 : 7FE200B1 : 1 : 1 : 272 : 0003C72C : Yes : Ok :
SRVM : 0 : Ad : 7FE200B2 : 7FE200B2 : 3 : 3 : 1508 : 00038600 : Yes : Ok : Module contains cylinder defects table
SRVM : 1 : Ad : 7FE210B2 : 7FE200B2 : 3 : 3 : 1508 : 00038600 : Yes : Ok : Module contains cylinder defects table
SRVM : F : Ad : 7FE000B2 : 7FE200B2 : 3 : 3 : 1508 : 00038600 : Yes : Ok : Module contains cylinder defects table
CHNL : 0 : B : 7FE200B5 : 7FE200B5 : 11 : 11 : 4924 : 00037000 : Yes : Ok :
CHNL : 1 : B : 7FE210B5 : 7FE200B5 : 11 : 11 : 4924 : 00037000 : Yes : Ok :
CHNL : F : B : 7FE000B5 : 7FE200B5 : 11 : 11 : 4924 : 00037000 : Yes : Ok :
IDNT : 0 : B : 7FE200C0 : 7FE200C0 : 2 : 2 : 184 : 0003A842 : Yes : Ok : HDD ID data module
IDNT : 1 : B : 7FE210C0 : 7FE200C0 : 2 : 2 : 184 : 0003A842 : Yes : Ok : HDD ID data module
IDNT : F : B : 7FE000C0 : 7FE200C0 : 2 : 2 : 184 : 0003A842 : Yes : Ok : HDD ID data module
SN00 : 0 : B : 7FE200C1 : 7FE200C1 : 1 : 1 : 20 : 0003A856 : Yes : Ok : Module contains HDD SN
SN00 : 1 : B : 7FE210C1 : 7FE200C1 : 1 : 1 : 20 : 0003A856 : Yes : Ok : Module contains HDD SN
SN00 : F : B : 7FE000C1 : 7FE200C1 : 1 : 1 : 20 : 0003A856 : Yes : Ok : Module contains HDD SN
MISC : 0 : B : 7FE200C2 : 7FE200C2 : 1 : 1 : 20 : 0003A910 : Yes : Ok :
MISC : 1 : B : 7FE210C2 : 7FE200C2 : 1 : 1 : 20 : 0003A910 : Yes : Ok :
MISC : F : B : 7FE000C2 : 7FE200C2 : 1 : 1 : 20 : 0003A910 : Yes : Ok :
ICES : 0 : B : 7FE200C3 : 7FE200C3 : 1 : 1 : 72 : 0003A930 : Yes : Ok : Security information module
ICES : 1 : B : 7FE210C3 : 7FE200C3 : 1 : 1 : 72 : 0003A930 : Yes : Ok : Security information module
ICES : F : B : 7FE000C3 : 7FE200C3 : 1 : 1 : 72 : 0003A930 : Yes : Ok : Security information module
MLBA : 0 : B : 7FE200C4 : 7FE200C4 : 1 : 1 : 10 : 0003A900 : Yes : Ok : HDD logical configuration module
MLBA : 1 : B : 7FE210C4 : 7FE200C4 : 1 : 1 : 10 : 0003A900 : Yes : Ok : HDD logical configuration module
MLBA : F : B : 7FE000C4 : 7FE200C4 : 1 : 1 : 10 : 0003A900 : Yes : Ok : HDD logical configuration module
QMCN : 0 : B : 7FE200C5 : 7FE200C5 : 4 : 4 : 2044 : 0003A000 : Yes : Ok :
QMCN : 1 : B : 7FE210C5 : 7FE200C5 : 4 : 4 : 2044 : 0003A000 : Yes : Ok :
QMCN : F : B : 7FE000C5 : 7FE200C5 : 4 : 4 : 2044 : 0003A000 : Yes : Ok :
SMRT : 0 : B : 7FE200C9 : 7FE200C9 : 1 : 1 : 420 : 0003C25A : Yes : Ok : S.M.A.R.T. module
SMRT : 1 : B : 7FE210C9 : 7FE200C9 : 1 : 1 : 420 : 0003C25A : Yes : Ok : S.M.A.R.T. module
SMRT : F : B : 7FE000C9 : 7FE200C9 : 1 : 1 : 420 : 0003C25A : Yes : Ok : S.M.A.R.T. module
PNID : 0 : D : 7FE200CA : 7FE200CA : 2 : 2 : 0 : 00FFFFFF : Yes : Ok : Module contains information from label on PCB
PNID : 1 : D : 7FE210CA : 7FE200CA : 2 : 2 : 0 : 00FFFFFF : Yes : Ok : Module contains information from label on PCB
PNID : F : D : 7FE000CA : 7FE200CA : 2 : 2 : 0 : 00FFFFFF : Yes : Error : Module contains information from label on PCB
ABLP : 0 : B : 7FE200CC : 7FE200CC : 1 : 1 : 104 : 0003AA20 : Yes : Ok :
ABLP : 1 : B : 7FE210CC : 7FE200CC : 1 : 1 : 104 : 0003AA20 : Yes : Ok :
ABLP : F : B : 7FE000CC : 7FE200CC : 1 : 1 : 104 : 0003AA20 : Yes : Ok :
ABLD : 0 : B : 7FE200CD : 7FE200CD : 1 : 1 : 144 : 0003A990 : Yes : Ok :
ABLD : 1 : B : 7FE210CD : 7FE200CD : 1 : 1 : 144 : 0003A990 : Yes : Ok :
ABLD : F : B : 7FE000CD : 7FE200CD : 1 : 1 : 144 : 0003A990 : Yes : Ok :
SSTL : 0 : B : 7FE200CE : 7FE200CE : 2 : 2 : 0 : 000FFFFF : Yes : Skip :
SSTL : 1 : B : 7FE210CE : 7FE200CE : 2 : 2 : 0 : 000FFFFF : Yes : Skip :
SSTL : F : B : 7FE000CE : 7FE200CE : 2 : 2 : 0 : 000FFFFF : Yes : Skip :
SERL : 0 : B : 7FE200D0 : 7FE200D0 : 2 : 2 : 1024 : 00036800 : Yes : Skip : S.M.A.R.T. error log module
SERL : 1 : B : 7FE210D0 : 7FE200D0 : 2 : 2 : 1024 : 00036800 : Yes : Skip : S.M.A.R.T. error log module
SERL : F : B : 7FE000D0 : 7FE200D0 : 2 : 2 : 1024 : 00036800 : Yes : Skip : S.M.A.R.T. error log module
SSST : 0 : B : 7FE200D2 : 7FE200D2 : 1 : 1 : 512 : 00036400 : Yes : Skip :
SSST : 1 : B : 7FE210D2 : 7FE200D2 : 1 : 1 : 512 : 00036400 : Yes : Skip :
SSST : F : B : 7FE000D2 : 7FE200D2 : 1 : 1 : 512 : 00036400 : Yes : Skip :
DCOT : 0 : B : 7FE200D3 : 7FE200D3 : 1 : 1 : 18 : 0003A830 : Yes : Ok :
DCOT : 1 : B : 7FE210D3 : 7FE200D3 : 1 : 1 : 18 : 0003A830 : Yes : Ok :
DCOT : F : B : 7FE000D3 : 7FE200D3 : 1 : 1 : 18 : 0003A830 : Yes : Ok :
SRIF : 0 : B : 7FE200D4 : 7FE200D4 : 1 : 1 : 2 : 0003CB2E : Yes : Ok : Self Test start management module
SRIF : 1 : B : 7FE210D4 : 7FE200D4 : 1 : 1 : 2 : 0003CB2E : Yes : Ok : Self Test start management module
SRIF : F : B : 7FE000D4 : 7FE200D4 : 1 : 1 : 2 : 0003CB2E : Yes : Ok : Self Test start management module
RDMT : 0 : Ad : 7FE40000 : 7FE40000 : 64 : 64 : 0 : 000A0000 : Yes : Ok : G-List module
RDMT : 1 : Ad : 7FE41000 : 7FE40000 : 64 : 64 : 0 : 000A0000 : Yes : Ok : G-List module
RDMT : F : Ad : 7FE01000 : 7FE40000 : 64 : 64 : 0 : 000A0000 : Yes : Ok : G-List module
RELI : 0 : B : 7FE40040 : 7FE40040 : 1 : 1 : 0 : 000A8000 : Yes : Skip :
RELI : 1 : B : 7FE41040 : 7FE40040 : 1 : 1 : 0 : 000A8000 : Yes : Skip :
RELI : F : B : 7FE01040 : 7FE40040 : 1 : 1 : 0 : 000A8000 : Yes : Skip :
PSHT : 0 : Ad : 7FE40041 : 7FE40041 : 482 : 98 : 0 : 000A8200 : No : : P-List module
PSHT : 1 : Ad : 7FE41041 : 7FE40041 : 482 : 482 : 0 : 000A8200 : Yes : Ok : P-List module
PSHT : F : Ad : 7FE01041 : 7FE40041 : 482 : 482 : 0 : 000A8200 : Yes : Ok : P-List module
OVR1 : 0 : B : 7FE50000 : 7FE50000 : 72 : 72 : 0 : 000FFFFF : Yes : Ok : Code overlay module
OVR1 : 1 : B : 7FE51000 : 7FE50000 : 72 : 72 : 0 : 000FFFFF : Yes : Ok : Code overlay module
SPRE : 0 : B : 7FE50048 : 7FE50048 : 54 : 54 : 0 : 000FFFFF : Yes : Skip :
SPRE : 1 : B : 7FE51048 : 7FE50048 : 54 : 54 : 0 : 000FFFFF : Yes : Skip :
PESD : : D : 7FE60000 : 7FE60000 : 128 : 128 : 0 : 000FFFFF : Yes : Ok : PES data log
MFGP : : Dr : 7FE61000 : 7FE61000 : 1 : 1 : 0 : 000FFFFF : Yes : Ok : Self Test parameters module
SRST : : C : 7FE70000 : 7FE70000 : 128 : 128 : 0 : 000FFFFF : Yes : Skip : Self Test report module
FLOG : : B : 7FE80000 : 7FE80000 : 128 : 128 : 0 : 000FFFFF : Yes : Skip :
DUMP : : D : 7FE90000 : 7FE90000 : 256 : 1 : 0 : 000FFFFF : No : : Self Test log
Modules checking completed
Information about copy 0
Report on module RSVD, "SA marker"
ABA..................................... : 7FD20000
Length (sectors)........................ : 3
Report on module RAM0, "Code module"
ABA..................................... : 7FE20002
Length (sectors)........................ : 138
FW Ver code............................. : 9948F63D
Report on module OVR0, "Code overlay module"
ABA..................................... : 7FE2008C
Length (sectors)........................ : 18
Report on module OVR1, "Code overlay module"
ABA..................................... : 7FE50000
Length (sectors)........................ : 72
Report on module IDNT, "HDD ID data module"
ABA..................................... : 7FE200C0
Firmware................................ : MBZO
Model................................... : HTS541010G9SA00
Serial.................................. : MP2ZX0XLGN59PS
Module not loaded! ID = CNS1 Copy 0; HDD logical configuration module
Error : Module is not loaded (CNS1, HDD logical configuration module)
Report on module MLBA, "HDD logical configuration module"
ABA..................................... : 7FE200C4
Capacity................................ : 0
Report on module ZONE, "Zone allocation table module"
ABA..................................... : 7FE200A5
Length (sectors)........................ : 10
Head count.............................. : 4
Full capacity........................... : 197660221
ABA sub-zones count..................... : 920
ABA sub-zones cyl. step by heads........ : 50 40 50 3B
# Init. Cyl End Cyl Head SPT
0 : 0 : 3599 : 0 : 946
: 0 : 2879 : 1 : 1012
: 0 : 3599 : 2 : 946
: 0 : 2639 : 3 : 1012
1 : 3600 : 5471 : 0 : 946
: 2880 : 6479 : 1 : 990
: 3600 : 5471 : 2 : 946
: 2640 : 5939 : 3 : 990
2 : 5472 : 9215 : 0 : 924
: 6480 : 8639 : 1 : 968
: 5472 : 9215 : 2 : 924
: 5940 : 7919 : 3 : 968
3 : 9216 : 12527 : 0 : 902
: 8640 : 11231 : 1 : 946
: 9216 : 12527 : 2 : 902
: 7920 : 10295 : 3 : 946
4 : 12528 : 15551 : 0 : 880
: 11232 : 15407 : 1 : 924
: 12528 : 15551 : 2 : 880
: 10296 : 14123 : 3 : 924
5 : 15552 : 17279 : 0 : 880
: 15408 : 18287 : 1 : 902
: 15552 : 17279 : 2 : 880
: 14124 : 16763 : 3 : 902
6 : 17280 : 20447 : 0 : 858
: 18288 : 20303 : 1 : 891
: 17280 : 20447 : 2 : 858
: 16764 : 18611 : 3 : 891
7 : 20448 : 22751 : 0 : 836
: 20304 : 22319 : 1 : 880
: 20448 : 22751 : 2 : 836
: 18612 : 20459 : 3 : 880
8 : 22752 : 25055 : 0 : 825
: 22320 : 25487 : 1 : 858
: 22752 : 25055 : 2 : 825
: 20460 : 23363 : 3 : 858
9 : 25056 : 26783 : 0 : 814
: 25488 : 27359 : 1 : 836
: 25056 : 26783 : 2 : 814
: 23364 : 25079 : 3 : 836
10 : 26784 : 29663 : 0 : 792
: 27360 : 29519 : 1 : 825
: 26784 : 29663 : 2 : 792
: 25080 : 27059 : 3 : 825
11 : 29664 : 31679 : 0 : 770
: 29520 : 31679 : 1 : 814
: 29664 : 31679 : 2 : 770
: 27060 : 29039 : 3 : 814
12 : 31680 : 34991 : 0 : 759
: 31680 : 35279 : 1 : 770
: 31680 : 34991 : 2 : 759
: 29040 : 32339 : 3 : 770
13 : 34992 : 38591 : 0 : 726
: 35280 : 38735 : 1 : 759
: 34992 : 38591 : 2 : 726
: 32340 : 35507 : 3 : 759
14 : 38592 : 42191 : 0 : 704
: 38736 : 42335 : 1 : 726
: 38592 : 42191 : 2 : 704
: 35508 : 38807 : 3 : 726
15 : 42192 : 44927 : 0 : 682
: 42336 : 45503 : 1 : 704
: 42192 : 44927 : 2 : 682
: 38808 : 41711 : 3 : 704
16 : 44928 : 48383 : 0 : 660
: 45504 : 46799 : 1 : 693
: 44928 : 48383 : 2 : 660
: 41712 : 42899 : 3 : 693
17 : 48384 : 50831 : 0 : 627
: 46800 : 48671 : 1 : 682
: 48384 : 50831 : 2 : 627
: 42900 : 44615 : 3 : 682
18 : 50832 : 52991 : 0 : 616
: 48672 : 51983 : 1 : 660
: 50832 : 52991 : 2 : 616
: 44616 : 47651 : 3 : 660
19 : 52992 : 55871 : 0 : 594
: 51984 : 53999 : 1 : 638
: 52992 : 55871 : 2 : 594
: 47652 : 49499 : 3 : 638
20 : 55872 : 58031 : 0 : 572
: 54000 : 56159 : 1 : 616
: 55872 : 58031 : 2 : 572
: 49500 : 51479 : 3 : 616
21 : 58032 : 60047 : 0 : 550
: 56160 : 58463 : 1 : 594
: 58032 : 60047 : 2 : 550
: 51480 : 53591 : 3 : 594
22 : 60048 : 63071 : 0 : 528
: 58464 : 61775 : 1 : 561
: 60048 : 63071 : 2 : 528
: 53592 : 56627 : 3 : 561
23 : 63072 : 66239 : 0 : 484
: 61776 : 66239 : 1 : 506
: 63072 : 66239 : 2 : 484
: 56628 : 60719 : 3 : 506
Report on module RDMT, "G-List module"
ABA..................................... : 7FE40000
Length (sectors)........................ : 64
Header
Capacity................................ : 3988
Defects count........................... : 16
In spare area........................... : 0
Described sectors in User Area.......... : 17
Totally remaped......................... : 6
SMART, Realloc Event Count.............. : 6
SMART, Pending Count.................... : 11
Data:
Candidate............................... : 11
Total hidden (cand.).................... : 11
Total hidden (grown).................... : 6
Information about copy 1
Report on module CNS1, "HDD logical configuration module"
ABA..................................... : 7FE200A3
AutoReassign............................ : OFF
Maximal LBA............................. : 195371567
Header
Data:
Information about factory copy
Module not loaded! ID = RSVD Copy F; SA marker
Error : Module is not loaded (RSVD, SA marker)
mu-code................................. : C6RR
Incompatible with NV-RAM!
FW Ver code............................. : FA9F30C5
Incompatible with active RESF!
AutoReassign............................ : ON
Header
Defects count........................... : 0
Described sectors in User Area.......... : 0
Totally remaped......................... : 0
SMART, Realloc Event Count.............. : 0
SMART, Pending Count.................... : 0
Data:
Candidate............................... : 0
Total hidden (cand.).................... : 0
Total hidden (grown).................... : 0
Information about common modules (Open+Spec)
Report on module MFGP, "Self Test parameters module"
ABA..................................... : 7FE61000
Level................................... : 0000
Heads................................... : 4
Zones................................... : 24
Cylinders............................... : 29439
RPM..................................... : 5423
SID`s................................... : 132
Bytes in ECC............................ : 51
SRVM cyl base........................... : 0
Zone # Init. Cyl SPT Last LBA
0 0 861 2147483646
1 65535 1 2147483646
2 65535 1 2147483646
3 65535 1 2147483646
4 65535 1 2147483646
5 65535 1 2147483646
6 65535 1 2147483646
7 65535 1 2147483646
8 65535 1 2147483646
9 65535 1 2147483646
10 65535 1 2147483646
11 65535 1 2147483646
12 65535 1 2147483646
13 65535 1 2147483646
14 65535 1 2147483646
15 65535 1 2147483646
16 65535 1 2147483646
17 65535 1 2147483646
18 65535 1 2147483646
19 65535 1 2147483646
20 65535 1 2147483646
21 65535 1 2147483646
22 65535 1 2147483646
23 65535 1 -1
The only important module bad is PSHT copy 0.
I read PSHT copy 1 and i try to write it on PSHT copy 0.
The follow error appear :
Test : Modules writing
Writing modules from profile folder
Folder: C:\Programmi\ACE Lab\PC-3000\Bin\!Profiles\HITACHI-IBM\HTS541\telmar\Data\Modules\Copy_1
Device error detected (INF)
Module is not written!
Module PSHT - ~PSHT.rpm................. : Error
Error : Error saving module PSHT copies: 0
Module writing completed
There is some metod to recovery data from this Hdd ?
Please is very urgent. Someone can help me ?
Bye :(
zhangbaizhen
Re: Problem with Hitachi HTS541010G9SA00 - Please Help me !
Postby zhangbaizhen » 14.02.09, 10:28
I can help you, you can use PC 3000 UDMA, data recovery
dmarques
Postby dmarques » 17.02.09, 15:36
Have you tried to open the module and write directly to the module itself?
