Hitachi Travelstar HTS541040G9AT00
Posted: 13.08.08, 11:34
by elgie
I have this 40GB Hitachi Travel Star. When i start my pc3000, it is going to ready state mode but it cannot read the HDD ID I try to select the correct HDD ID but still same problem. I try to replace the hdd pcb. Anyone can help me?? Thanks
Posted: 13.08.08, 15:14
by Igor
Hello Elgie,
I would like to see your report.
Regards,
Posted: 14.08.08, 08:27
by elgie
Loading data for correction of HDD family handling settings from section DPTA
Selected family......................... : HTS541
Model by ID............................. : <ID IS NOT READ>
NV-RAM reading.......................... : Ok
Module not read (RESF)
Error : Device error detected (ABR)
Error :............................................................... : Module not read (RESF)
Module is not loaded (RESF, Main module table)
Error :............................................................... : Error executing loading "open" modules dir command
Module ZONE is not found!
Posted: 19.08.08, 16:07
by narro
I think on 2 possibilities: PCB damage or pre-amplifier damage.
I have seen similar failures on this models. The drives spins up, but the spindle does not leave the parking area (it does not move). You can open it and check. Good luck
Posted: 20.08.08, 08:11
by elgie
what if the problem will be in pre-amplifier?? how can i repair it?? do i need to change any thing?? thanks
Posted: 20.08.08, 15:26
by narro
If pre-amplifier is damage, you need you change the whole headstack....
Try first to transplat NVRAM to new PCB board.
