Hitachi Deskstar hdd
Posted: 21.05.08, 13:05
by elgie
I have this MAC Server hdd which configured in RAID5. I try to run partition analysis and create virtual partition. Still no luck. Maybe somebody can help me with this. Many thanks
Posted: 23.05.08, 10:09
by dmarques
First of all please explain the problem better.
How many drives has the array? Does it have any drive damaged or are they all ok?
Did you try to rebuild the array?
Posted: 24.05.08, 08:26
by elgie
First i have 14 hard drive in the server. There is 1 hdd that is damage btu all of the hdd is healthy. I try to rebuild the array but it didnt become successful. So i try to get the data on each hdd through data extractor. It is showing files in the RAW recovery but the files that im getting is all corrupted.
Posted: 26.05.08, 10:04
by dmarques
First, how did you try to rebuild the array?
It's a MAC XServer with 7 + 7 drives?
Second, getting the data from each hdd will be of no use, as it will be all damaged.
Posted: 26.05.08, 13:49
by elgie
Yes , it is a MAC Xserver 7+7 hdd. I just rebuild to array of it. Is there other way to recover data on it??
Posted: 27.05.08, 10:02
by dmarques
There are some other options.
How did you rebuild the array?
