Problem with Hitachi HDS722525VLAT80.
Posted: 21.03.08, 10:14
I have a strage problem with Hitachi HDS722525VLAT80.
I connect it to PC3KUDMA, and power on.
After some time the Hdd go to ready.
I start the utility, and the program report "Hdd ID as not be read. Error : Error reading HDD ID (ABR). Run Utility ?"
I press YES button and appear the follow messages "Cannot identify the Hdd family". I press OK.
Now i press UTILITY START.
The utility start but do not recognize ID model.
If i try a Tools -> Drive ID, i can see the correct Drive IDs !!!!!!
First Question :Why to utility start the PC3KUDMA cannot read ID ?
Now i run a SA Structure test. Follow the report :
Selected family......................... : VLAT
Model by ID............................. : HDS722525VLAT80
ROM ID.................................. : A60A
NV-RAM ID............................... : V3UOA60A
USAG version............................ : V3UOA60A
NV-RAM parameters
NV-RAM report
Loaded.................................. : Yes
Checksum................................ : Ok
ID...................................... : E2PR
mu-code................................. : V3UOA60A
FW Ver Code............................. : 0x8A629828
Heads................................... : 6
Head map................................ : 5 4 3 2 1 0
Module copy ABA modifier for SA......... : 0x1000
Base for cyl defect list................ : 2052
SA top cyl delimiter.................... : 0xED72
Used module table
Report on module USAG, "Main module table"
ABA..................................... : 7FE20000
Length (sectors)........................ : 2
Identified.............................. : Yes
FW Ver code............................. : 8A629828
ID : Copy : Importn.: ABA : ABA : Size : Read : Size : Address in : Read : Hdr : Description
original): (sect): (sect): (byte) : RAM : : :
RSVD : 0 : B : 7FD20000 : 7FD20000 : 4 : 4 : 2048 : 00000000 : Yes : Ok : SA marker
RSVD : 1 : B : 7FD21000 : 7FD20000 : 4 : 4 : 2048 : 00000000 : Yes : Ok : SA marker
RSVD : F : B : 7FD60000 : 7FD20000 : 4 : 0 : 2048 : 00000000 : No : : SA marker
USAG : 0 : B : 7FE20000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
USAG : 1 : B : 7FE21000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
USAG : F : B : 7FE60000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
PSHT : 0 : Ad : 7FE40000 : 7FE40000 : 229 : 229 : 0 : 00007800 : Yes : Ok : P-List module
PSHT : 1 : Ad : 7FE41000 : 7FE40000 : 229 : 1 : 0 : 00007800 : No : : P-List module
PSHT : F : Ad : 7FE61000 : 7FE40000 : 229 : 229 : 0 : 00007800 : Yes : Ok : P-List module
RDMT : 0 : Ad : 7FE400E5 : 7FE400E5 : 32 : 32 : 16384 : 00024200 : Yes : Ok : G-List module
RDMT : 1 : Ad : 7FE410E5 : 7FE400E5 : 32 : 32 : 16384 : 00024200 : Yes : Ok : G-List module
RDMT : F : Ad : 7FE610E5 : 7FE400E5 : 32 : 32 : 16384 : 00024200 : Yes : Ok : G-List module
RLBA : 0 : B : 7FE200B9 : 7FE200B9 : 1 : 1 : 102 : 00030700 : Yes : Ok : G-List reserves table module
RLBA : 1 : B : 7FE210B9 : 7FE200B9 : 1 : 1 : 102 : 00030700 : Yes : Ok : G-List reserves table module
RLBA : F : B : 7FE600B9 : 7FE200B9 : 1 : 1 : 102 : 00030700 : Yes : Ok : G-List reserves table module
CNSL : 0 : B : 7FE2009F : 7FE2009F : 1 : 1 : 216 : 0003D6A4 : Yes : Ok : HDD logical configuration module
CNSL : 1 : B : 7FE2109F : 7FE2009F : 1 : 1 : 216 : 0003D6A4 : Yes : Ok : HDD logical configuration module
CNSL : F : B : 7FE6009F : 7FE2009F : 1 : 1 : 216 : 0003D6A4 : Yes : Ok : HDD logical configuration module
RWCN : 0 : B : 7FE200A0 : 7FE200A0 : 1 : 1 : 100 : 0003D2B4 : Yes : Ok :
RWCN : 1 : B : 7FE210A0 : 7FE200A0 : 1 : 1 : 100 : 0003D2B4 : Yes : Ok :
RWCN : F : B : 7FE600A0 : 7FE200A0 : 1 : 1 : 100 : 0003D2B4 : Yes : Ok :
CHNM : 0 : B : 7FE200C5 : 7FE200C5 : 31 : 31 : 11269 : 00035080 : Yes : Ok :
CHNM : 1 : B : 7FE210C5 : 7FE200C5 : 31 : 31 : 11269 : 00035080 : Yes : Ok :
CHNM : F : B : 7FE600C5 : 7FE200C5 : 31 : 31 : 11269 : 00035080 : Yes : Ok :
SRVP : 0 : B : 7FE200A3 : 7FE200A3 : 1 : 1 : 456 : 00038880 : Yes : Ok :
SRVP : 1 : B : 7FE210A3 : 7FE200A3 : 1 : 1 : 456 : 00038880 : Yes : Ok :
SRVP : F : B : 7FE600A3 : 7FE200A3 : 1 : 1 : 456 : 00038880 : Yes : Ok :
SRVM : 0 : Ad : 7FE200BA : 7FE200BA : 11 : 11 : 5580 : 00038A80 : Yes : Ok : Module contains cylinder defects table
SRVM : 1 : Ad : 7FE210BA : 7FE200BA : 11 : 11 : 5580 : 00038A80 : Yes : Ok : Module contains cylinder defects table
SRVM : F : Ad : 7FE600BA : 7FE200BA : 11 : 11 : 5580 : 00038A80 : Yes : Ok : Module contains cylinder defects table
ZONE : 0 : Ad : 7FE200B5 : 7FE200B5 : 3 : 3 : 1310 : 0003BF80 : Yes : Ok : Zone allocation table module
ZONE : 1 : Ad : 7FE210B5 : 7FE200B5 : 3 : 3 : 1310 : 0003BF80 : Yes : Ok : Zone allocation table module
ZONE : F : Ad : 7FE600B5 : 7FE200B5 : 3 : 3 : 1310 : 0003BF80 : Yes : Ok : Zone allocation table module
PTRT : 0 : B : 7FE200B8 : 7FE200B8 : 1 : 1 : 480 : 00033400 : Yes : Ok :
PTRT : 1 : B : 7FE210B8 : 7FE200B8 : 1 : 1 : 480 : 00033400 : Yes : Ok :
PTRT : F : B : 7FE600B8 : 7FE200B8 : 1 : 1 : 480 : 00033400 : Yes : Ok :
RAM0 : 0 : B : 7FE20002 : 7FE20002 : 57 : 57 : 29184 : 0004C000 : Yes : Ok : Code module
RAM0 : 1 : B : 7FE21002 : 7FE20002 : 57 : 12 : 29184 : 0004C000 : No : : Code module
RAM0 : F : B : 7FE60002 : 7FE20002 : 57 : 57 : 29184 : 0004C000 : Yes : Ok : Code module
OVR1 : 0 : B : 7FE2003B : 7FE2003B : 85 : 85 : 8704 : 00053200 : Yes : Ok : Code overlay module
OVR1 : 1 : B : 7FE2103B : 7FE2003B : 85 : 85 : 8704 : 00053200 : Yes : Ok : Code overlay module
OVR1 : F : B : 7FE6003B : 7FE2003B : 85 : 85 : 8704 : 00053200 : Yes : Ok : Code overlay module
SMRT : 0 : B : 7FE200A7 : 7FE200A7 : 1 : 1 : 243 : 0003BC20 : Yes : Ok : S.M.A.R.T. module
SMRT : 1 : B : 7FE210A7 : 7FE200A7 : 1 : 1 : 243 : 0003BC20 : Yes : Ok : S.M.A.R.T. module
SMRT : F : B : 7FE600A7 : 7FE200A7 : 1 : 1 : 243 : 0003BC20 : Yes : Ok : S.M.A.R.T. module
MLBA : 0 : B : 7FE200A8 : 7FE200A8 : 1 : 1 : 46 : 0003D64A : Yes : Ok : HDD logical configuration module
MLBA : 1 : B : 7FE210A8 : 7FE200A8 : 1 : 1 : 46 : 0003D64A : Yes : Ok : HDD logical configuration module
MLBA : F : B : 7FE600A8 : 7FE200A8 : 1 : 1 : 46 : 0003D64A : Yes : Ok : HDD logical configuration module
SECI : 0 : B : 7FE200A9 : 7FE200A9 : 1 : 1 : 74 : 0003BBD0 : Yes : Ok : Security information module
SECI : 1 : B : 7FE210A9 : 7FE200A9 : 1 : 1 : 74 : 0003BBD0 : Yes : Ok : Security information module
SECI : F : B : 7FE600A9 : 7FE200A9 : 1 : 1 : 74 : 0003BBD0 : Yes : Ok : Security information module
SRIF : 0 : B : 7FE200A4 : 7FE200A4 : 1 : 1 : 2 : 0003D690 : Yes : Ok : Self Test start management module
SRIF : 1 : B : 7FE210A4 : 7FE200A4 : 1 : 1 : 2 : 0003D690 : Yes : Ok : Self Test start management module
SRIF : F : B : 7FE600A4 : 7FE200A4 : 1 : 1 : 2 : 0003D690 : Yes : Ok : Self Test start management module
SERL : 0 : B : 7FE200AB : 7FE200AB : 3 : 3 : 1536 : 00034000 : Yes : Ok : S.M.A.R.T. error log module
SERL : 1 : B : 7FE210AB : 7FE200AB : 3 : 3 : 1536 : 00034000 : Yes : Ok : S.M.A.R.T. error log module
SERL : F : B : 7FE600AB : 7FE200AB : 3 : 3 : 1536 : 00034000 : Yes : Ok : S.M.A.R.T. error log module
IDNT : 0 : B : 7FE200A1 : 7FE200A1 : 2 : 2 : 532 : 0003BD40 : Yes : Ok : HDD ID data module
IDNT : 1 : B : 7FE210A1 : 7FE200A1 : 2 : 2 : 532 : 0003BD40 : Yes : Ok : HDD ID data module
IDNT : F : B : 7FE600A1 : 7FE200A1 : 2 : 2 : 532 : 0003BD40 : Yes : Ok : HDD ID data module
DCOT : 0 : B : 7FE200AA : 7FE200AA : 1 : 1 : 10 : 0003D678 : Yes : Ok :
DCOT : 1 : B : 7FE210AA : 7FE200AA : 1 : 1 : 10 : 0003D678 : Yes : Ok :
DCOT : F : B : 7FE600AA : 7FE200AA : 1 : 1 : 10 : 0003D678 : Yes : Ok :
PTCH : 0 : B : 7FE20090 : 7FE20090 : 2 : 2 : 1024 : 00055400 : Yes : Ok : Microcode connections table module
PTCH : 1 : B : 7FE21090 : 7FE20090 : 2 : 2 : 1024 : 00055400 : Yes : Ok : Microcode connections table module
PTCH : F : B : 7FE60090 : 7FE20090 : 2 : 2 : 1024 : 00055400 : Yes : Ok : Microcode connections table module
##01 : 0 : : 7FE20092 : 7FE20092 : 13 : 13 : 6656 : 00000001 : Yes : Skip : Main SA track hole
##01 : 1 : : 7FE21092 : 7FE20092 : 13 : 13 : 6656 : 00000001 : Yes : Skip : Main SA track hole
##01 : F : : 7FE60092 : 7FE20092 : 13 : 13 : 6656 : 00000001 : Yes : Skip : Main SA track hole
##02 : 0 : : 7FE200A5 : 7FE200A5 : 2 : 2 : 1024 : 00000001 : Yes : Skip : Main SA track hole
##02 : 1 : : 7FE210A5 : 7FE200A5 : 2 : 2 : 1024 : 00000001 : Yes : Skip : Main SA track hole
##02 : F : : 7FE600A5 : 7FE200A5 : 2 : 2 : 1024 : 00000001 : Yes : Skip : Main SA track hole
##03 : 0 : : 7FE200AE : 7FE200AE : 7 : 7 : 3584 : 00000001 : Yes : Skip : Main SA track hole
##03 : 1 : : 7FE210AE : 7FE200AE : 7 : 7 : 3584 : 00000001 : Yes : Skip : Main SA track hole
##03 : F : : 7FE600AE : 7FE200AE : 7 : 7 : 3584 : 00000001 : Yes : Skip : Main SA track hole
RDM1 : : Ad : 7FE400E5 : 7FE400E5 : 32 : 32 : 0 : 00000000 : Yes : Ok : G-List module (RDM1 - reference to RDMT)
RDM2 : : Ad : 7FE410E5 : 7FE410E5 : 32 : 32 : 0 : 00000000 : Yes : Ok : G-List module (copy)
ELG1 : : C : 7FEC1000 : 7FEC1000 : 512 : 3 : 0 : 00000000 : No : : Log module
EVLG : : C : 7FEC0000 : 7FEC0000 : 512 : 512 : 0 : 00000000 : Yes : Ok : Log module (event log)
PID1 : : D : 7FE200A5 : 7FE200A5 : 2 : 2 : 0 : 00000000 : Yes : Ok : Module contains information from label on PCB
PID2 : : D : 7FE210A5 : 7FE210A5 : 2 : 2 : 0 : 00000000 : Yes : Ok : Module contains information from label on PCB
PIDM : : D : 7FEA0059 : 7FEA0059 : 3 : 3 : 0 : 00000000 : Yes : Ok : Module contains information from label on PCB
PDM1 : : Ad : 7FE40000 : 7FE40000 : 229 : 229 : 0 : 00000000 : Yes : Ok : P-List module (PDM1 - reference to PSHT)
PDM2 : : Ad : 7FE41000 : 7FE41000 : 229 : 6 : 0 : 00000000 : No : : P-List module (copy)
HLR1 : : B : 7FEA00E0 : 7FEA00E0 : 5 : 5 : 0 : 00000000 : Yes : Ok : Factory tests log module (HLRC)
HLR2 : : B : 7FEA10E0 : 7FEA10E0 : 5 : 0 : 0 : 00000000 : No : : Factory tests log module (HLRC, copy)
MFGP : : Dr : 7FEA0000 : 7FEA0000 : 2 : 2 : 0 : 00000000 : Yes : Ok : Self Test parameters module
AMPM : : B : 7FEA0006 : 7FEA0006 : 1 : 0 : 0 : 00000000 : No : : Factory tests log module (AMPM)
DDD0 : : B : 7FEA0004 : 7FEA0004 : 2 : 2 : 0 : 00000000 : Yes : Skip : DDD utility log module
DIAG : : B : 7FEA005C : 7FEA005C : 100 : 100 : 0 : 00000000 : Yes : Skip : Native diagnostic utilities log module
WRT0 : : B : 7FE00000 : 7FE00000 : 16 : 16 : 0 : 00000000 : Yes : Skip : Marker at head 0
WRT1 : : B : 7FE01020 : 7FE01020 : 16 : 16 : 0 : 00000000 : Yes : Skip : Marker at head 1
WRT2 : : B : 7FE02040 : 7FE02040 : 16 : 1 : 0 : 00000000 : No : : Marker at head 2
WRT3 : : B : 7FE03060 : 7FE03060 : 16 : 1 : 0 : 00000000 : No : : Marker at head 3
WRT4 : : B : 7FE04080 : 7FE04080 : 16 : 1 : 0 : 00000000 : No : : Marker at head 4
WRT5 : : B : 7FE050A0 : 7FE050A0 : 16 : 1 : 0 : 00000000 : No : : Marker at head 5
@@01 : : : 7FEA0002 : 7FEA0002 : 2 : 0 : 1024 : 01EAB272 : No : : Additional SA track hole
@@02 : : : 7FEA0007 : 7FEA0007 : 82 : 0 : 41984 : 01EAB272 : No : : Additional SA track hole
@@03 : : : 7FEA00C0 : 7FEA00C0 : 32 : 31 : 16384 : 01EAB272 : No : : Additional SA track hole
PESD : : D : 7FE90000 : 7FE90000 : 128 : 128 : 65536 : 00000000 : Yes : Error : PES data log
SRST : : C : 7FEB0000 : 7FEB0000 : 255 : 0 : 130560 : 00000000 : No : : Self Test report module
SSSC : : Dr : 7FEA0009 : 7FEA0009 : 5 : 5 : 2560 : 00000000 : Yes : Skip : Self Test management and status module
SSCD : : Dr : 7FEA0018 : 7FEA0018 : 49 : 49 : 25088 : 00000000 : Yes : Skip : Self Test code module
NVRC : : Dd : 7FEA01FE : 7FEA01FE : 2 : 2 : 1024 : 00000000 : Yes : Ok : NV-RAM image module
Modules checking completed
Information about copy 0
Report on module RSVD, "SA marker"
ABA..................................... : 7FD20000
Length (sectors)........................ : 4
Report on module RAM0, "Code module"
ABA..................................... : 7FE20002
Length (sectors)........................ : 57
mu-code................................. : A60A
Report on module OVR1, "Code overlay module"
ABA..................................... : 7FE2003B
Length (sectors)........................ : 85
Report on module IDNT, "HDD ID data module"
ABA..................................... : 7FE200A1
Firmware................................ : V36OA60A
Model................................... : HDS722525VLAT20
Serial.................................. : VNR9HEC6C8XNNL
Report on module CNSL, "HDD logical configuration module"
ABA..................................... : 7FE2009F
Length (sectors)........................ : 1
AutoReassign............................ : ON
Maximal LBA............................. : 488397167
Report on module MLBA, "HDD logical configuration module"
ABA..................................... : 7FE200A8
Capacity................................ : 488397168
Report on module ZONE, "Zone allocation table module"
ABA..................................... : 7FE200B5
Length (sectors)........................ : 3
Zones count............................. : 30
# Init. LBA Init. Cyl End Cyl SPC SPT
0 : 0 : 0 : 1499 : 7020 : 1170
1 : 10528830 : 1500 : 5899 : 6882 : 1147
2 : 40807336 : 5900 : 10299 : 6882 : 1147
3 : 71084695 : 10300 : 14260 : 6804 : 1134
4 : 98034205 : 14261 : 17656 : 6750 : 1125
5 : 120954955 : 17657 : 22656 : 6480 : 1080
6 : 153351715 : 22657 : 27656 : 6480 : 1080
7 : 185749555 : 27657 : 31456 : 6156 : 1026
8 : 209140303 : 31457 : 35256 : 6156 : 1026
9 : 232531051 : 35257 : 38368 : 6072 : 1012
10 : 251426103 : 38369 : 42031 : 5940 : 990
11 : 273182343 : 42032 : 44101 : 5832 : 972
12 : 285253611 : 44102 : 46969 : 5670 : 945
13 : 301514226 : 46970 : 50002 : 5508 : 918
14 : 318218154 : 50003 : 53008 : 5400 : 900
15 : 334449654 : 53009 : 55736 : 5262 : 877
16 : 348802636 : 55737 : 58683 : 5130 : 855
17 : 363919891 : 58684 : 62083 : 4860 : 810
18 : 380442271 : 62084 : 65483 : 4860 : 810
19 : 396965461 : 65484 : 68883 : 4452 : 742
20 : 412100777 : 68884 : 72283 : 4452 : 742
21 : 427236093 : 72284 : 75512 : 4320 : 720
22 : 441184653 : 75513 : 77341 : 4212 : 702
23 : 448887699 : 77342 : 79491 : 4050 : 675
24 : 457594524 : 79492 : 81641 : 4050 : 675
25 : 466301349 : 81642 : 83924 : 3888 : 648
26 : 475177005 : 83925 : 86209 : 3780 : 630
27 : 483813045 : 86210 : 87957 : 3642 : 607
28 : 490179261 : 87958 : 88057 : 3564 : 594
29 : 490535661 : 88058 : -1 : 3564 : 594
Report on module SRVM, "Module contains cylinder defects table"
ABA..................................... : 7FE200BA
Length (sectors)........................ : 11
Defects count........................... : 69
Report on module RDMT, "G-List module"
ABA..................................... : 7FE400E5
Length (sectors)........................ : 32
Header
Capacity................................ : 1900
Defects count........................... : 0
Grown................................... : 0
Data:
Candidate............................... : 0
Total hidden (cand.).................... : 0
Total hidden (grown).................... : 0
Information about copy 1
Module not loaded! ID = RAM0 Copy 1; Code module
Error : Module is not loaded (RAM0, Code module)
Header
Data:
Information about factory copy
Module not loaded! ID = RSVD Copy F; SA marker
Error : Module is not loaded (RSVD, SA marker)
mu-code................................. : V3SOA60A
Incompatible with NV-RAM!
Maximal LBA............................. : 490234751
Capacity................................ : 490234752
Header
Data:
Information about common modules (Open+Spec)
Report on module PIDM, "Module contains information from label on PCB"
ABA..................................... : 7FEA0059
PN...................................... : 08K0466
PCB ID.................................. : 14R9219J41048_Xd73470GN9
Report on module MFGP, "Self Test parameters module"
ABA..................................... : 7FEA0000
Level................................... : 0000
Zones................................... : 30
Cylinders............................... : 88248
RPM..................................... : 7200
SID`s................................... : 270
Bytes in ECC............................ : 52
SRVM cyl base........................... : 2052
Zone # Init. Cyl SPT Last LBA
0 0 1170 10528829
1 1500 1147 40807335
2 5900 1147 71084694
3 10300 1134 98034204
4 14261 1125 120954954
5 17657 1080 153351714
6 22657 1080 185749554
7 27657 1026 209140302
8 31457 1026 232531050
9 35257 1012 251426102
10 38369 990 273182342
11 42032 972 285253610
12 44102 945 301514225
13 46970 918 318218153
14 50003 900 334449653
15 53009 877 348802635
16 55737 855 363919890
17 58684 810 380442270
18 62084 810 396965460
19 65484 742 412100776
20 68884 742 427236092
21 72284 720 441184652
22 75513 702 448887698
23 77342 675 457594523
24 79492 675 466301348
25 81642 648 475177004
26 83925 630 483813044
27 86210 607 490179260
28 87958 594 490535660
29 88058 594 -1
The only BAD important module is PSHT COPY 1 and PDM2.
I try to rewrite PSHT COPY 1 with COPY 0 but a error message appear.
I try to use SECTOR EDIT on TOOLS menu, and i try to read some sector. I can read it !!!!.
If i try to run DATA EXTRACTOR for cloning the Hdd, Data Extractor report the error "Hdd ID as not be read. Error"
Second Question : Why i cannot rewrite the BAD module ?
Last Question :Why, if i can read sector with SECTOR EDIT, i can not cloning the Hdd with Data Extractor ?
Some one can help me ?
Bye
NV-RAM parameters
NV-RAM report
Used module table
Header
Data:
Header
Data:
Header
Data:
0 0 1170 10528829
29 88058 594 -1
Bye
