head swap on HDP725050GLA360 P/N 0A37728
hddr49
Postby hddr49 » 14.10.13, 17:43
Hi there,
I'm looking for donnor drive.
This P/N is very diffucult to obtain, so I try to obtain information on users that have successfully swap heads with differents P/N
(original topic here for this drive : viewtopic.php?f=2&t=7842)
Thanks for help !
dmarques
Re: head swap on HDP725050GLA360 P/N 0A37728
Postby dmarques » 26.11.13, 13:58
I think it's better for you to get a donor than to do hotswap on those.
hddr49
Postby hddr49 » 27.11.13, 12:38
yes, but I don't find any donnor for this one.
search for it since 6 month...
dmarques
Postby dmarques » 27.11.13, 15:29
Why don't you forget about P/N and just buy the same model?
Postby AJ2008 » 27.11.13, 15:50
datalabace wrote:Why don't you forget about P/N and just buy the same model?
Totally agree. PN may be preferable, but in my experience it does not always need to be perfectly matched, in some successful cases there is even no match to PN...
hddr49
Postby hddr49 » 27.11.13, 17:17
unfortunally already bought 2 of same model
heads don't match. Unlucky guy ?
donnor heads are ok, I back them into donnor drive
patient heads don't work in donnor drive
I search same P/N or same MLC ... what else ?
dmarques
Postby dmarques » 27.11.13, 17:59
What do you mean they don't work, they knock?
hddr49
Postby hddr49 » 29.11.13, 11:29
yes, they knock.
dmarques
Postby dmarques » 29.11.13, 12:09
Do you have microscope to check head pattern?
hddr49
Postby hddr49 » 02.12.13, 14:31
no, I don't.
But I can buy one if relevant.
dmarques
Postby dmarques » 03.12.13, 10:00
I think it's a must have tool in your LAB!
hddr49
Postby hddr49 » 04.12.13, 08:59
ok then.
where should I look on the heads to see head pattern ?
compare with other good heads ?
dmarques
Postby dmarques » 05.12.13, 12:19
You should compare it with your donors.
hddr49
Postby hddr49 » 06.12.13, 09:24
thanks for your helps.
I will do this.
We learn every day in data recovery...
