Dear all board users and AceLab Stuff. At the first time, i wish you all, a very happy new Year!
I can't find in the userguide of PC-3000UDMA, how to enable writing factory modules.
But i have two Hitachi HTS541 drives with the same problem RSVD 0 and 1 are ok, but the factory module can't be read. Only the factory Module RSVD and the DUMP Module are bad.
How i can solve this problem.
Thanks for any Help.
Bruno
Factory copy enable
Re: Factory copy enable
Hi Bruno,
You don't need to.
That modules are always bad.
Have you tried to access sectors of the drive?
You don't need to.
Hi datalabace
zhank you for your engagement.
Yes now i tried, and have access. I read about 280000 sec. then i switched off the drive and connect a backup hd on channel 2. after start to copy sectors, i can't read any sectors...
what could bee, the problem?
Bruno
Bruno
Make SA test again and post the results.
Dear datalabace
Your tip: make another SA-Test was helpfull!!
i comparing the new sa-test log with an earlier from the same HD and found difference.
Both modules OVR0 and OVR1 inthe earlier log has this entry:
mu-code................................. : C60R
and in the new log there are C6TR....
I also write the original Module OVR0 and OVR1 back to the Disc.
Now i can recover the data from this HD.
But why this entry has changed???
I dont touch it!!
Bruno
I dont touch it!!
Bruno
Hi Bruno,
I really don't know why that change.
Had to analyse the case from the beginning to try to understand that.
Hi datalabace
I think the key to the bad Modules is a moribund Head Preamp or ReadWrite-Channel.
I recover about 64'000'000 sectors, then the head make noises (clacking). That is enough, because on the drive are 10GB of data stored.
I have all!
When i have more time, i try to analize them, but for the moment i have to do many urgent work. (Much HD and Memorycards to recover)
Thanks for help
Bruno
Thanks for help
Bruno
