Trange problem with HTS541060G9SA00
Powermax
Postby Powermax » 16.01.08, 10:58
I have strange problem with Hitachi HTS541060G9SA00 ( 60Gb Sata ).
When i power on it, go to ready without knoking, but PC3KUDMA can not identify the Hdd family.
I run the HTS541 utility and make a SA Check. The only bad module module is PSHT Copy0.
The Copy 1 and F Copy is good. When i try to write module PSHT Copy0 with module PSHT Copy1, all seem to be OK, but when i check module PSHT Copy 0 again, this seem to be BAD.
Some one can help me ?
Another question is :
Why PC3KUDMA do not recognize the Hdd Family is all module except PSHT copy 0, are good ?
What is the module responsable for idetifications Hdd Family ?
Please help me !!!!! :?
dmarques
Postby dmarques » 16.01.08, 15:43
Hi Powermax,
I already had 2 of those cases.
First of all, if you have PList damaged, most probably utility won't ID the drive.
If you tried to copy from copy 1 to copy 0 and copy is always bad, that means that the area where PList is located is damaged.
From what I know you don't have any way to solve it.
Powermax
Postby Powermax » 16.01.08, 16:07
There is no way to use Plist Copy 1 and not Plisit Copy 0 ?
The copy 1 is perfectly readed.
The copy 0 start to read but on 60% return an read error.
Thank you anymore.
Vikas
Postby Vikas » 21.03.08, 08:17
I tried a mathord and got little success.
I have opened the Hitachi utility with no id and serial# of drive. My PLIST copy0 was bad (bad sector).
so no other way to repair it.
Then i opened the DE and unselected the "READ DRIVE ID" and manualy inserted the size of hard disk. and Clone to Image
Then in DE in Task parameter I have selected read from active PC3000 utility. BINGO got nearly 60% of the data very nicely. but for 40% i am working.
Hope this will help some one or if u have a good meathord please post it.
Vikas :)
www.datatracksystem.net
dmarques
Postby dmarques » 24.03.08, 10:00
Thanks for the tip.
I'll check if I still have here some of those drives and test it out.
dobrevjetser
Postby dobrevjetser » 06.05.08, 17:09
Hi guys,
I've got exactly the same problem with a HTS541010G9SA00.
The drive does not ID, error on loading open modules; only copy 0 of plist is defective.
Also using the active pc3k utility, i can read about 60000 sectors.
Then the rest becomes unreadable.
Any tips on how to progres with this drive ?
Thanks in advance,
Dobre
dobrevjetser
Postby dobrevjetser » 13.05.08, 16:20
Roustam,
You told me you were going to pass this on to an engineer. Any news yet ?
This data is urgent !
Thanks in advance.
Dobre
