HM500JI stay busy after Hot swapping : No overlay code
Posted: 19.05.14, 22:02
Hi there,
I have one HM500JI with no terminal output at all.
Let's go for hot swapping...
like another user,
1. Power on donor. Run the utility. Wait until initialization will complete,then put drive to sleep mode. - OK
2. Unscrew the PCB from donor and install it on patient drive.Screw the screws back. And perform recalibration. - OK
3. Wait until the drive will enter ready state, then read the modules from the drive except some "big capacity" log modules. -OK (I read all modules and save)
4. Power off donor PCB and swap it on donor HDA. - OK
5. Write all necessary modules(All of them - family is not in the list) from patient to donor drive .Then switch drive's Power off/on. - stop..
When switch drive's Power off/on then doner HDD is not ready.
It stay busy, and I have terminal output :
I try to check the modules integrity, but there are 148 of them...
can you help me ?
thanks
like another user,
Code: Select all
*PA VID=0007 PN=0000 Rev=0004
PSL
U
S_0Shock Sensor Circuit Enabled
SO_1
Init RPM=0
IS=5
CLA #36/74
Handoff RPM=606
SPOK
mS1 00000003
A1O=124 A1G=441
O=511 S=7
SK C: 4558 H:0
Loaded FIT ( 0: 0: 1)
Reso Table Loaded
RRO1X Read OK
No Overlay code
can you help me ?
thanks
