Samsung HD502HJ turns five seconds and it stopped
Posted: 28.04.14, 13:56
by Hoang21
I have a Samsung HD502HJ hard drive
P / N: HD502HJ / B
Rev: A
Frm: 1AJ100002
he turns five seconds and it stopped and the PC 3000 can not detect.
I took voltage PCB and compare with other PCBs, there are the same voltage.
Can you help me Please
thank you
cordially
Re: Samsung HD502HJ turns five seconds and it stopped
Posted: 28.04.14, 14:47
Probably is some problem with Alist or SMART.
After it stops, can you send soft reset (or maybe several) and does it show ID then?
Posted: 29.04.14, 16:39
by Hoang21
I can not see HDD ID
Model: HDD ID has not been read
serial:
firmware:
Capacity: ,49 MB (1000)
In Termial: LED 1A04
Thank
AJ2008 wrote:Probably is some problem with Alist or SMART.
Posted: 29.04.14, 17:04
There is option to solve this within utility. If you search this forum for LED 1A04 you should find more info on it
