HD502HJ - how to write ROM via terminal
Posted: 23.10.13, 16:07
I have HD502HJ with the same problem as described in this post
viewtopic.php?f=33&t=7812&start=0
i.e. drive does not spin and stays busy with client PCB and donor PCB with client ROM. I have gained terminal access as per instruction manual. ROM dump is
Dump size............................... : 524288 bytes
Firmware checksum....................... : Ok
FIPS offset............................. : 0x00070000
FIPS size............................... : 1024 bytes
FIPS checksum........................... : Error
Firmware type........................... : Main Code
Original name........................... : 1AJc3suM.125
Platform Id............................. : 0x19
Head map................................ : 0, 1, 2, 3
I understand this is a FIPS error.
I have copied FIPS section from the donor to client ROM.bin file using HexEdit. When I check this Repaired_rom.bin file in utility everything looks fine like this
Information about dump
FIPS checksum........................... : Ok
Test completed
I am now trying to write this Repaired_ROM.bin file to the ROM via utility terminal. The utility copies 256kb only (ROM is 512kb) and stops with error:
Write ROM
From file............................... : E:\List\13377-Repaired_rom.bin
Download via terminal................... : Yes
Disable checking HDD Patform Id......... : No
Checksum verification................... : Ok
Loader checking......................... : Ok
Loading................................. : Error downloading file via terminal; Terminal is busy
Operation aborted
Test completed
I understand that the easiest solution is to use external EPROM programmer (as the guy in the earlier post did), which I don't have and this job is rather urgent.
How can I write ROM via terminal - am I doing something wrong here?
Test completed
Write ROM
Operation aborted
Test completed
