ST1000LM024 HN-M101MBB
Posted: 08.02.13, 12:06
Situation:
At power-on ONLY LED BSY is constantly active!
After testing and change the following components (I have a identical HDD):
PCB, Heads (complet with magnet), initialize the HDD and I could access it through the normal Samsung tools.
Then I read ROM, ...
Everything is working normally.
https://www.dropbox.com/s/a6ctmgilourl2sm/03a%20read%20fips%20module.PNG
Now = DataExt. started and launched Explorer, open the Explorer.
I tried to open the file list (root), HDD went to BUSY.
I've tried soft reset, hard reset, HDD does not respond.
I rebooted and left all the initialization for a long time.
After the last minutes of trading, initialize the HDD.
I tried again Samsung Tools and in this situation, now load modules from SA:
https://www.dropbox.com/s/7dtlmx50yt617qo/04e%20reading%20modules%2004.PNG
Sometimes I have a BSY LEd and afther (maybe 5min) Led BSY is OFF and HDD is OK!
Again entered the DataExt., Explorer, ...
https://www.dropbox.com/s/vf4k51of6awskxe/03c%20DE%20explorer.PNG
Foe exampe I want to save a folder "SLIKE I SNIMCI", I check and click on Save Marked = Led BSY is ON!!!
I hear from HDD: bzzz, bzzzz, tk, tk, tk, tk! Again and again.
In one situation I have a ERROR:
https://www.dropbox.com/s/wlxnoitwjh9mtxk/05%20reading%20service%20tracks.PNG
Now no matter what I try to do with him, he went to work and automatically BUSY Soft reset, several times and HDD again came to the "normal" state, but they can change with it, because every time I try something, HDD
always restarts (Soft).
WHAT SHOULD I DO?
WHAT SHOULD I DO?
