Samsung M40S Magma 2.5" LED 2A01 error
Posted: 22.10.12, 22:22
I am working on a Samsung 2.5" HDD that I believe is in the M40S magma family. It stays busy when it is powered up and has a somewhat buzzing sound, but the drive does spin. When I connect the just the PCB to PC-3000 and run the specialized utility I get a constant message in the terminal "LED 2A01". The log message is:
"Techno mode error: unexpected error: Drive is not ready
Utility initialization was terminate!"
So I know that the LED code 0x2A is "too many pes error" (not sure what that means) but I don't know of one for 0x01, so not sure if this is a unique LED code of the combination of 2. Only idea I have at this point is that maybe the heads are stuck.
When the PCB is connected to the HDD I get "LED 110B" in the terminal. The drive starts to spin, then clicks and then spins down.
Model HM500JJ
Rev A
F/W: 2AK10002
Model HM500JJ
Rev A
F/W: 2AK10002
