BSY with terminal errors LED 1A03/LED 1A04
Posted: 08.12.11, 09:05
The new Samsung drives (3.5" F1_3D, 2.5" M7S2 and newer) that show 2-byte errors in terminal and have read/write errors in SA can't get ready state (after softreset).There's a special command that helps to force the HDD initialization.
1. Turn drive on, run Samsung utility
2. Open terminal window
3. Restart power of HDD and wait till you get an error LED 1A03/LED 1A04
4. Enter the command "LE"
The drive will spin up and initialize by ATA, launch SA structure test then. (usually A-list clean is required)
