How to connect terminal and SATA interface to USB drives
Posted: 11.11.11, 13:48
by Igor
Hello guys
We can connect terminal to Samsung USB drives using diagrams below
For MT1
For M7S2
Sometimes we need to connect SATA interface to USB PCB. We can do it using next diagrams
This is schema of SATA connector
We should solder it on the place of 4 capacitors between SATA chip and USB chip. Capacitors should be unsoldered before.
When you unsolder one capacitor you get 2 pins. One goes to main chip and second goes to USB chip. So when we will unsolder 4 capacitors we will get 8 pins. We should solder sata connector to 4 pins that go to main chip.
On the diagrams below we can see places of capacitors (they are marked by red rectangles) and digits.
Pins number 3, 2, 5, 6 of SATA connector should be soldered to appropriate (by written digits) pins on the pcb.
Schema of MT1
SATA MT1.png (187.05 KiB) Viewed 14135 times
Schema for M7S2
SATA M7S2.png (752.13 KiB) Viewed 14135 times
Schema for M7E
SATA M7E.png (133.62 KiB) Viewed 14135 times
Re: How to connect terminal and SATA interface to USB drives
Posted: 30.07.13, 12:16
by hdrescue
Hello guys,
Do you have the diagram to connect sata interface to MT2 USB pcb?
I have one of those that I need to convert to sata. Let me know if you can help me with this one.
Regards,
Tiago Filipe
Posted: 29.05.15, 13:00
by eazycut
Hi.
I need layout for USB -> SATA On Samsung with PCB: M8U.
Anyone has layout for M8U usb to SATA?
Thx
Eazycut
