HD153WI
Posted: 23.03.11, 13:26
by ththeod
hi to all!
Log:
Family selected: F3_4D(SATA)
Technological ID
Techno mode error; unexpected error: Drive is not ready
Techno passport not loaded
Zone allocated table not loaded!
SA SPT.................................. : 1584
! Modules table used by default
Utility initialization was terminate!
Test completed
Table of zone translation
Reading module PARAM_DM................. : Techno mode error; unexpected error: Drive is not ready
Terminal:
*PA VID=0000 PN=0008 Rev=0001- 785x Found
nChipRev = 53C2U
S_0
RV Sensor Circuit Enabled
Shock Sensor Circuit Enabled
SO_1
SpinStartUp: mcSpinRPM = 0
RPM at Handoff: 555
Temp : 21 degC
SpinOk
mS1 00000003
UF 3 1stGrayErr Hd:0
PK_3 C: 0 H:0
SK C:160337 H:1
S_0SR:0
AP:1 C: 10870-> 10720 H:1->0 AP Cnt: 0
SK C: 22669 H:1
SR:1
AP:1 C: 22669-> 10720 H:0->0 AP Cnt: 0
SK C: 22692 H:1
SR:2
AP:1 C: 22692-> 10720 H:0->0 AP Cnt: 0
SK C: 22670 H:1
SR:3
AP:1 C: 22670-> 10720 H:0->0 AP Cnt: 0
SoUL WO Cal!
PK_1 C: 22670 H:0
PK_3 C: 0 H:0
SK C:161527 H:1
AP:1 C:161527-> 10720 H:0->0 AP Cnt: 0
SK C:156861 H:1
S_0SR:0
AP:1 C:156861-> 10720 H:0->0 AP Cnt: 0
SK C:149693 H:1
SR:1
AP:1 C:149693-> 10720 H:0->0 AP Cnt: 0
SK C:148538 H:1
SR:2
AP:1 C:148538-> 10720 H:0->0 AP Cnt: 0
SK C:147356 H:1
SR:3
AP:1 C:147356-> 10720 H:0->0 AP Cnt: 0
SoUL WO Cal!
PK_1 C:147356 H:0
PK_3 C: 0 H:0
Drive does not ID.
This repeats to infinity...
heads?
Re: HD153WI
Posted: 29.03.11, 12:27
by ACE_Admin
Most likely this drive has problems with its 0th head. This Samsung hard drive family has 3 system heads. Power it on and let this drive knock for 2-3 minutes, it will go to DRD DSC state and let you read the data from its good heads(need to build a head map within Data Extractor).
If you need only a few files from that drive, the method with reading the data from healthy heads may work, in other case swap the heads from same model donor drive.
